Wells/Conrad SU-145 MAF Availability...
Old Apr 20, 2001 | 10:54 PM
Vader's Avatar
This has been asked several times, so I finally got around to checking with Wells Manufacturing Corp. and tried to get a list of retail outlets for their products. Most of their parts are fairly generic, and are no better nor worse than any number of other ignition and sensor parts you can find at discount prices.
However, for a few bucks more they do offer a Wells Gold and the Conrad line that are more of a premium quality. Among these parts is the SU-145 MAF. This is a direct replacement for the Bosch analog MAF on many of our cars ('86-'89) but shares many of the features of the LT1-style MAF, such as a thick film sensor instead of a hot wire, no heat sink, larger I.D. housing, and a single flat metal matrix on the inlet instead of the round wire screens as found in the Bosch units. Flow is improved and the survivability of the sensor is nearly thermonuclear-resistant. I have heard from some that the MAF does not mount well in situations where the OEM clamp had been screwed to the MAF housing, but most installations are identical to the original.
Since many have asked where to get one, the factory replied:
"We suggest contacting Neil at World Discounts @ 800-288-6728 or Chris at Ace Warehouse @ 605-342-4710 to purchase any Wells products. If they do not stock an item they will be willing to special order it and will drop ship orders directly to your business or residence."
Maybe that will be of benefit to someone.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 20, 2001 | 11:08 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Cool, thanks Vader!!
Old Apr 21, 2001 | 09:56 AM
BLOWN85/TA's Avatar
May the force be with you Vader! Good info super mod. I'm holding out for the big ford conversion piece and 512GM, cant wait. Wells thick film piece is probably the best way to replace the old Bosch heated wire unit on most normal MAF cars.
Old Apr 21, 2001 | 02:27 PM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
Vader does it again! Now a MAF question...My 85 has the Bosch MAF and was built 6/85. Is this the 1986+ "fast" baud rate computer or the older "slow" one? When I run Diacom it works without the special TPI adapter. I can only wish that it's the improved version so I won't have to fool with the expensive MAF burn off module when it decides to die.
85 IROC,LB9,t-tops,hard loaded,black with red Lear-Siegler "Camaro" interior,MacEwen white guages,145 speedo,decal delete,91 Bose stereo,stage 2 Fastchip,AFPR,airfoil,K&Ns,March pulleys,alum. driveshaft&spare,92 police version 700r4.
On the list: BW 3.27 posi,89 PBR rear discs,140a police alt,coated TES,glass hood,aluminum front bumper brace
"Use overdrive for high speed pursuit"
Old Apr 21, 2001 | 05:37 PM
irocbob89's Avatar
have any of you herd about the conversion box from granitelli that will let us tpi guys use the ford maf sensor on ower maf cars? I have a friend that said something about this. i was just wondering about any maf things i can do. Im need alot more air into my engine because im running to rich, i have #30 injectors and 255 high pressure fuel pump and i think im running way to rich and i may have to switch back to #24's and i really dont want to do that. Thanks
Bobby
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
slp cam 224 230 535 544
1.6rr
edelbrock performers p+p
ford 9', 4.11, 31 spline
baer rear brakes
line lock
all the bolt ons
200 shot on the way
Old Apr 21, 2001 | 11:43 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROCKZE:
</font>
IROC,
You might be one of the fortunate few that has the late '85 TPI. If your ECM is P/N 1227165, you have the newer control and MAF. The digital MAF used on early TPI engines was produced by Delco Electronics, and the later analog MAF was produced by Robert Bosch, and should have the part number on the electronics package cover. The part numbers are 0280 213 004 (Bosch) and GM part number 14094712, and reads "Made in Germany".
Later,
Vader
"What a Day..."
[This message has been edited by Vader (edited April 23, 2001).]
Old Apr 22, 2001 | 09:13 PM
IROCKZE's Avatar
Engine: 5.0 DOHC
Thanks Vader! I will have myself a look and keep my fingers crossed.
Old Apr 23, 2001 | 08:08 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Hey Vader... the Bosch could be used for either setup, either the 165 or 870. I know when my MAF fried about 3 years ago a Bosch was pulled out (still have it) and a Bosch was put in.. not sure of the part #'s, I can check when I get home.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 23, 2001 | 03:53 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Vader,
Are you sure about that "made in Germany" MAF?
Old Apr 23, 2001 | 03:58 PM
Vader,
Some time ago I tried to order it by the part number over here in Holland at a Bosch Service center,they didn't list it because it was a USA-Bosch part,made in the USA.....
(There is a Bosch sign and a number on my MAF,but no "made in Germany!)
Old Apr 23, 2001 | 09:36 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Dutch-Bird:
Vader,
</font>
Yes, I'm fairly certain...
Later,
Vader
"What a Day..."
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
