Got worked by a Mustang, Help!
Old May 1, 2001 | 07:04 PM
Casey'91Z28's Avatar
I raced a mustang yesterday from about 80 to 100 and he took me pretty bad about 2 to 3 carlengths. It was like a 91-93(not sure) LX 5.0, I don't know what mods it had. I was wondering what I could do to help out my car, what should I do next? My mods are in my signature.
'91 Z28 305, Auto trans, K&N filters, TPIS air foil, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, SLP 1 5/8" headers, catco 3" cat, 14.7@ 93 mph.
Old May 1, 2001 | 07:43 PM
MrJ's Avatar
MrJ
Sounds like your car does exactly what mine does: fall on its face on top end. Your 320+ ft lbs of torque gets you out of the hole like a bastard, but the inherent limitation of TPI (and the small bore 305) makes them poor cars for high speed racing. I've lost track of the number of cars that I've taken 0-90, only to be walked from there on up.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old May 1, 2001 | 07:55 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
There are some pretty bad 91-93 5.0 LXs running around. Friend of mine named Bob Cosby has one that runs low 11's high 10s and he drives it to work every day.
So unless you know the modification level of the car you raced, don't feel so bad.
And yes, stock TPI cars start to run out of steam at that speed, our torque is down lower.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 2, 2001 | 09:59 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
yank that 305 out aand put in a 383 the tourque will be amazing with tpi or go with a short runner intake
Old May 2, 2001 | 10:22 PM
RoadRocket L98's Avatar
Dump the 305 and drop in a carbed 383, if the Stangs still cause you trouble, invest in the lil blue bottle.
'83 Firebird 2.8
'89 Firebird Formula 350
Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
ET? About on par with a worn out 305...
Old May 3, 2001 | 01:37 AM
Reno's Avatar
Unless you want to do the major work these guys have mentioned, then yeah, go to the Blue Bottle Insurance Company. Start to lose at top end, press a button, win. Pretty simple. Or, be a safer street racer, and shut down around 70-80, so you seem like the good guy racer, AND you're still in your power range.
-Reno
89 Formula
Old May 3, 2001 | 03:53 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
you can also get rid of that pathetic cam that you have in there. Go to a junk yard and find a L98 cam and throw it in there or better yet buy a good cam out of a magazine.
Old May 3, 2001 | 04:07 PM
MrJ's Avatar
MrJ
<font face="Verdana, Arial" size="2">Originally posted by Drkhrse89:
you can also get rid of that pathetic cam that you have in there. Go to a junk yard and find a L98 cam and throw it in there or better yet buy a good cam out of a magazine.</font>
It's already there. You need to get informed.
Old May 4, 2001 | 03:32 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I say don't go and change your engine, if it runs good why do that?? Make yours better, build it up. Get some really good flowing heads, much better cam,(like Comp Cams) a custom PROM or Fastchip, ram air, or even a S/C.
[This message has been edited by IROCZTWENTYGR8 (edited May 04, 2001).]
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
twest2k2
Aug 24, 2015 11:26 AM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
