What is everyones TPS set at?
Old Apr 24, 2001 | 11:08 AM
spyderman's Avatar
Mine is set at .60 volts. It just was always at that. What is the best setting? I have a custom chip. Does that affect anything?
Old Apr 24, 2001 | 12:08 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
.54 volts is stock. Chips are usually programmed using the stock setting as a start off point.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Apr 26, 2001 | 06:38 PM
90Form350's Avatar
Any where from .47 to .61 is normal (for 1990 TPI Firebirds anyway). I would look around the net a little bit, guaranteed someone has it posted somewhere. I dont think there is anything about 3rd gen F-bodies that isnt online.
Old Apr 26, 2001 | 09:02 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
from everything i have read .64 is max before the check engine light shines.
white/gold GTA ,leather 5.7TPI 700r4 3:27posi twin cats aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods& performance resource chip
Old Apr 26, 2001 | 10:17 PM
Vader's Avatar
540mV
Old Apr 27, 2001 | 06:12 PM
spyderman's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Vader:
540mV</font>
Is that the amount of volts your boyfriend uses on your nipples Vader? lol
Old Apr 30, 2001 | 09:36 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by spyderman:
</font>
Who the hell are you??
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 30, 2001 | 10:53 AM
spyderman's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin Irving:
</font>
Someone who runs a hell of a lot faster than 15.5 !
Look how many mods you have. tsk tsk
Old Apr 30, 2001 | 12:08 PM
Car: 1985 Trans Am
Hey spyder.... you're pretty new here, I wouldn't be cutting on people with your perverted sense of entertainment, especially one of the more knowledgeable guys like Vader. Watch yourself or you'll find yourself at the top of many people's ignore list.
Wow.... you run faster than 15.5? I'm impressed, but not with your lack of class.
Old Apr 30, 2001 | 12:35 PM
spyderman's Avatar
I've seen Vaders posts. Sounds like the guy reads right out of a Chiltons repair manual. A lot of "internet mechanics" around here huh?
Old Apr 30, 2001 | 07:28 PM
Car: 1985 Trans Am
Congratulations Spyder, with just 7 posts you've mangaged to alienate (look it up) most of the people on this board who highly respect Vader, GM Tech, RB, RCR, and the other "internet mechanics" here. Let the doorknob hit ya where the dog shoulda bit ya a$$hole.
By the way, if you're so freakin fast, why don't you post your times?? And why do you find it necessary to post a question like "what is your TPS set at?" if you're such an expert?
You know, this sounds a lot like NUN.....
Old Apr 30, 2001 | 08:43 PM
spyderman's Avatar
ok. 12.3@110mph. 60ft 1.9
355TPI A4 ported stock intake,vortech s trim,as&M siamesed runners,accel 24# injectors,edelbrock jet hot coated 1 5/8ths,flowmaster catback,tpis airfoil,comp cam 1.5 and 1.6 roller rockers,MSD6A,255/50/16 bg goodrich drs,steve spohn sfcs,tpis level 5 magnum prom
Old Apr 30, 2001 | 09:15 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
8.4v
92 RS, 350, Street & Performance MPFI, TFS heads,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old May 1, 2001 | 04:13 AM
Car: 1985 Trans Am
</font>
Uh huh..... ok....
And I have my TPS set at 110v.
Old May 1, 2001 | 06:49 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
hey spyder if u are so knowledgable why did u even post this thread? I mean since your car is just like "the ****" why even bother...
Vader knows more than you will ever will little boy
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old May 1, 2001 | 06:51 AM
fly89gta's Avatar
Car: 2018 Camaro SS
another thing....how are u pulling 12.3's with only a 1.9 60' time? i've seen high 13 second cars pull those times
Old May 1, 2001 | 06:59 AM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
His mods sure do look like he read them straight out of a few catalogs sittin' on his computer desk.
Old May 1, 2001 | 04:06 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
street & performance says for best performance it should be set at .84
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
t-56 trans
9" ME rearend
Old May 1, 2001 | 09:55 PM
poncho9789's Avatar
I was just curious when I looked at this thread. I am new to 3rd gens I also have a 4th gen. I have been looking on the thirdgen bords for about a month I have found most of the guys on this bord to be the most knolageable on the net. To all the guys like vader I thank you for all the tec info that you despence at no cost and as a new member I appologise for all the ****** that will ask for help and then trash the guys that want to help.
thanks guys
Old May 1, 2001 | 10:39 PM
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by camaro1j:
</font>
.84v will almost definately set a code.... the upper limit with stock prom is .61v and even with a custom burned prom like Spidey says he has I can't imagine it being that high. Then again when your mods are all in your mind like his probably are anything is possible.
Old May 2, 2001 | 10:03 AM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
I have tpi on my truck and it is set too .84 with no problems. It doesn't flash codes and it runs great!
406
accel supper ram
afr heads
t-56 trans
9" ME rearend
Old May 2, 2001 | 10:29 AM
spyderman's Avatar
yeeee haw kevin , I like that big bird thing on your hood . bwhahahahahah
Old May 2, 2001 | 11:49 AM
Car: 1985 Trans Am
Let me guess.... when you were a baby you were breast fed by your father and this is the way you are rebelling?? Grow up, ****head. 9 posts and 6 of them are nothing but childish rants.
Old May 2, 2001 | 12:15 PM
lb9formula91's Avatar
im new to thirdgens and i know somethings about them but where and how do you adjust the tps. I want my car running better and i want to know how to adjust it thanks guys
91 formula
305 tpi
borla exhaust
white face gauges
home made cold air
tpis airfoil
Old May 2, 2001 | 02:57 PM
the roc's Avatar
syderman,, do you have a 305 or 350?
https://www.thirdgen.org/messgboard/...ML/000725.html
Old May 2, 2001 | 03:38 PM
rezinn's Avatar
That airfoil you got doesn't work well with the stock TPS, you should go to kalecoauto to get the performance tps for such high flow. The guys at pep boys recommend running higher voltage with sfcs, but Im not sure how high. Maybe you should ask Steve about that one.
Old May 2, 2001 | 03:43 PM
rezinn's Avatar
Didn't see your post, formula91. You need to unscrew the torx bolts in the side of the tps to move it up and down, this adjusts the voltage. You need a voltmeter to check it though. By moving it around you can pretty much tell where you want it, as the idle will speed up or slow down. The tps is on the passenger side of your throttle body, it has a connector going into it. I know someone has a pic around here, but its really obvious.
Old May 2, 2001 | 07:15 PM
thanks for the info
Old May 3, 2001 | 02:20 PM
Ken88GTA's Avatar
LOL, the roc!!!!!
Old May 3, 2001 | 02:37 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Acually Street and Performance does recommend .84v but with there systems.
Oh, and it does not set off any codes.
Crane Rollers,
[This message has been edited by 92 RSS (edited May 03, 2001).]
Old May 3, 2001 | 03:07 PM
Car: 1985 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by the roc:
</font>
Oh Sheehott!!! Spyder got caught in a lie!! Now what was that he said?? BWAAAHAAAHAAAA??? ROTLMFAO!! This is hilarious!! Hey Spyder... give me those times and mods again boy!!!
Old May 4, 2001 | 01:42 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Old May 4, 2001 | 01:49 PM
Kevin G's Avatar
I think you can go up to .91vs before a code sets. So the range is between .40s-.90 I think.
I set mine at .63v
Spyderman.. This is not a flame board. Knock it off.
Old May 4, 2001 | 02:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
lb9Formula, you can find info on it in this thirdgen.org tech article (by Tom K): https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
