Is DFI worth the money on a N/A motor??
Old May 7, 2001 | 04:37 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm just wondering if DFI would be worth the money if used on an N/A motor? It'd be on a 383, possibly with SR manifold, runners, and plenum, and a possible 100 hp shot on those "special occasions." Thanks.
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd B&M Ripper shifter, hopefully I can rob a bank or something and get more
www.geocities.com/irocnroll90
Old May 7, 2001 | 08:57 PM
a383z's Avatar
DFI is very much worth it I run a 383 with the Lingenfelter set up and I was running a modified chip untill about a week ago and my car is alot smoother idling now. But I can change it so sucks down fuel and bump the timing for the track. Besides the cost I dont understang why you wouldn't go DFI, its great.
1992 383 Z-28 w/SuperRam intake and ACCEL DFI(waiting on AFR heads this winter)
Old May 7, 2001 | 10:28 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i agree the dfi is a good buy its also good
for future mods if you need to change
them.
check out my simple page at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old May 7, 2001 | 10:38 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
a383z, tell me more about your dfi experiences. From your mods it sounds like you have the exact same combo I'm building except I'm going to run iron eagle heads. I was going to sell my accel/fasttrack dfi setup & burn proms, but since nobody seems to want my dfi I guess I'm going to just use it.
I really did want to keep my maf though... *sigh*
[This message has been edited by irocz (edited May 07, 2001).]
Old May 8, 2001 | 06:46 AM
a383z's Avatar
Well my setup is an Accell intake w/30lb injectors, I put the regular setup on top of my 383 first and then put the SuperRam on later. With the GM computer it always took some time for the computer to find an idle at start up and when I decelerated to a stop but as soon as the DFI went in it idles great just like stock kind of just alot louder. I run Lingenfelter headers (bought them before they were discontinued)and a Dynomax muffler. Any questions I can answer just ask.
Old May 8, 2001 | 07:06 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I love my DFI. The DFI is more straight forward than burning PROMs. I only wish I had learned PROM burning so I understood what they talk about on the PROM board.
Old May 8, 2001 | 02:46 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
a383Z what are you running, or what type or power are you making, or both? What kind of internals are you using, all cast, all forged, a combination? Thanks.
Old May 8, 2001 | 03:28 PM
CanadianBeast's Avatar
I've never used DFI but I'll tell you that prom burning ain't rocket science, especially for a SD system. Go to the prom board and read a little, Traxions tech article in particular, I think you'll find that it's pretty straight forward and well worth the time invested to learn it. Plus it cheaper than DFI
Old May 9, 2001 | 06:27 AM
a383z's Avatar
I run Keith Black pistons chevy pink rods and a forged crank, its a custom ground cam but I might upgrade to a Lunati when I put the AFR heads on. I make approx 450 hp and 530 lb/ft tq. I didn't build it the best its what I could aford at the time(4 years ago) When this motor dies I will go with the good stuff.
Old May 11, 2001 | 12:58 AM
irocz's Avatar
Car: '87 IROC-Z
What did you go through when you installed the dfi? I've got this setup that comes with a fasttrack performance interface that's supposed to let the dfi work through the stock computer, but I haven't actually gotten under the dash to see how it hooks up. I'm building a 6" rod 383. You think 24lb SVO injectors will be enough?
thanks,
Dan
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
1992rs/ss
Jan 31, 2025 05:10 PM
jhawkeye
May 25, 2022 06:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
lt1z350
Aug 28, 2015 05:57 AM
marcusaw
Aug 10, 2015 08:13 AM
