350 TPI on 305?
Old May 15, 2001 | 11:29 AM
Lov2xlr8's Avatar
350 TPI on 305?
What changes need to be made to make an 350 setup run correctly on an 305?
Old May 15, 2001 | 11:37 AM
maksik7's Avatar
Post on Motor Swap, you'll get much more answers there.
BTW That question was already beaten to death, and you can find many responses just on the first page of Motor Swap board
-Max
Old May 16, 2001 | 09:55 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I am running a 350 TPI on my lightly modded 305. No changes were needed. Runs great. No trouble codes or problems at all.
Old May 16, 2001 | 10:07 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Same stuff, different injectors and knock sensor.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old May 17, 2001 | 12:07 AM
Lov2xlr8's Avatar
Do you run too rich? does it bog down at all? I keep hearing about tht knock sensor, the one from my TBI wont work huh? Well, i will have to see how it runs I guess, Any way, Thanks for taking time to post, I appreciate your replies.
Old May 17, 2001 | 05:29 AM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
No, it runs great. The extra fuel from the 350 injectors helps it run better. My 305 is modified with a cam and aftermarket heads. If you are doing this with a basically stock 305, you may or may not have a rich condition. The knock senser I used cam out of a 305 TBI parts car. No problem with using that. For peace of mind you could just get a new one.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
