383 SuperRam Cam Selection
Old May 26, 2001 | 12:15 PM
RGS1260's Avatar
Any one ever use Comp Cams TPI Hyd Roll
grinds.383 SportsmanIIs SuperRam 700R4 3.73
30Ib injectors 58mm Throttle Body.
Hows idle and performance?
CS-276HR-14 220/230 @.050 510/510 114
CS-290HR-12 230/244 @.050 510/540 112 2000-6000
Extreme Marine
12-418-8 224/230 @050
503/510 112 1800-5800
Having them custom ground on small base circle. Milage and emmissions not an issue.
[This message has been edited by RGS1260 (edited May 26, 2001).]
Old May 26, 2001 | 12:48 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
I have a crane cam it has alot of power.
119831
grind # hr-284-2s-12 IG
222.0-230.0 duration
509-528 lift
2500-6000 RPM
LOOK AT MY WEB SITE FOR THE REST OF MY MODS.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old May 26, 2001 | 02:07 PM
Mojo's Avatar
I use the Lingenfelter 74219 cam. It was designed specifically for the Superram.
408cid 1985 Corvette
http://www.mojosgarage.com
Old May 29, 2001 | 11:58 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I've always heard too that superrams don't like split duration cams and that's why the lingenfelter cams for it aren't split.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, tb airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear :/
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old May 30, 2001 | 03:00 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
The LPE "219" cam was designed to be used in conjunction with a SR and LPE's vette heads on their crate engines.Their vette heads have a smoking exhaust port so the cam doesn't need a larger exhaust lobe.You will probably need a dual pattern because stock Sportsman's have weak exhaust port numbers.
92Z28
89GTA
[This message has been edited by Acceld Z (edited May 30, 2001).]
Old May 30, 2001 | 06:06 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
idles like stock and pulls all the way to 6500(I never tried passing it)
Daz
87 IROC 3.27,S10 converter,TFS G1 heads,52mm TB
[This message has been edited by Daz (edited May 30, 2001).]
Old Jun 1, 2001 | 06:22 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
IM running the 213 LPE cam in my 406. Its designed for 383-406 sb chevys inconjuction with the SuperRam. Just FYI The 219 cam isnt the only one designed for this intake. The 213 has 224*-234* of split duration. I havent installed the motor yet so I cant say how it performs.
Something in the low 220s is right on target with the combo you are building IMO.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jun 1, 2001 | 07:17 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I've done a ton of comparisons on my engine analyzer, and for overall performance, you can't beat the LPE 219 cam. I've got one that I am putting in my 383 next month. Of all the cams I tested, the CC306 made about 10-15 more hp than the 219, but the 219 had a higher avg torque and hp curve of all the cams.
With your Dart's, I'd get some port work done on them. They seem to have a pretty weak exhaust port, and bad intake/exhaust ratio. If you run them stock, you are probably better off with a split duration cam, although the 219 will work. I'd go with the CC306 or the 219, with the CC304 or ZZ409 cams being close behind.
Jorlain
Oct 8, 2015 01:57 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
