30psi for oil pressure?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Is that okay for it to be at when Its been runnning for a while and at idle. It goes up to 45 when i drive but just curious as to the idling at 30psi
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 30psi for oil pressure?
Should be fine, according to my manual.
Axle/Gears: 3.27 BW
I've heard that a smallblock only needs 5-10 psi at idle, but I am not sure if there's any truth to this.
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey kowboy59, 30 PSI at idle is fine. Now 5-10 PSI I think is stretching it.
If my '88 GTA ever drops below 20 PSI, a switch on the oil sender shuts
off the fuel pump thus saving the engine from oil starvation.
" The secret of life is honesty and fair dealing...
If you can fake that you've got it made. "
Groucho Marx
Groucho Marx
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Mine was reading between 5 and 10 psi at idle for a long time , one day at a stop light it shot up to over 60 and stayed there , I replaced the sending unit and now at idle it runs around 35 .
Car: 92 Camaro RS
Engine: 5.0 TBI
My oil pressure jumps all over the place, it has never got down to 5-10 psi though. Is the needle jumping around normal for these cars? It doesn't jump around constantly but it does range anywhere between 25-60 psi.
Where is the sending unit located? Do you think I need to change it and how hard is it to change?
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I don't think that's true. As far as I know, the switch keeps the pump running as long as there is oil pressure, but it's only there in case the relay fails. If the relay is good low oil pressure won't kill the pump.
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
My sending unit is located right above the oil filter , apparently their notorious for being inaccurate and are prone to failure .
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
What he said may very much be the truth. You can purchase the sender thru most auto parts / racing catalogs as I did. In my case if the pressure drops below 20, a super bright light (simular to an autometer shift light) comes on and the pump shuts down. It's not a plug and play deal though. You have to wire it in that way.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Ya... He could have wired it this way, but the stock configuration is exactly how jv9999 stated.
Car: '88gta
Engine: 383 tpi
if you can fake that,you've got it made. "
Groucho Marx
Engine: 5.7L/350
Let's see here, are you saying the purpose of the switch is to protect the fuel pump relay from low oil pressure ???? If the relay fails, the pump shuts down regardless of oil pressure - high or low. The engine needs protection from low oil pressure ( in my case below 20 psi ) not a failed fuel pump relay - No?
Groucho Marx
Groucho Marx
+1.
I did my whole wiring harness. That is how it is from the factory, no question about it. The oil pressure switch is only there in case the relay fails.
