FUEL PUMP BLUES
Old Jun 22, 2001 | 05:05 PM
Fast86TA's Avatar
FUEL PUMP BLUES
ok, I need a new fuel pump, I want to put on an electric external, I don't have a whole lot of horses so I don't need something HUGE so I looked at Holley's Standard Pressure pump, BUT it says not recomended for fuel injection..... so my problem is that I need an electric external pump for a fuel injected car with not a whole lot of mods, but a few... nothing major
Old Jun 23, 2001 | 05:29 AM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
call summit racing or jegs. they're pretty good at finding what you need. electric fuel pumps for fuel inj. produce a much higher pressure than standard electric ones.
Old Jun 25, 2001 | 02:59 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I got a Holley external 45psi fuel pump from Summit. Total was $142 and change shipped to my home.
We installed it today. Took us about 4 hours to do the complete install.
You will need to get a new intank pickup from a carbed car if you want to go external.
I have an intank pump and sender for sale. It is mounted to the bracket that goes into the tank and has the wires already on it.
You'd just yank yours out and put this one in.
I'll let you have it for $50.00
Old Jun 25, 2001 | 08:08 AM
91-ZZ4-Z28's Avatar
Do your self a favor and get an in tank pump, external pumps a very loud and will annoy the crap out of you. It is not hard to put an in tank pump in and doesn’t take very long.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Old Jun 25, 2001 | 01:01 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
94-ZZ4-Z28,
Installing an in-tank FP does not take very long?? Do you have a secret for getting out the FP without dropping the Axel & Exhaust that I don't know about? I am interested, cause I have thought about changing my FP.
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 25, 2001 | 01:18 PM
Fast86TA's Avatar
See the thing is I JUST replaced my intank pump like 2 months ago, and it took us forever, granted it was our first time doing it, but still. plus it costs alot more than an external.... if you figure 70$ for the pump, 90$ to get the exhaust welded back up.... which is hard to find a place that will do exhaust work when you have not cats.. and then whatever the fine was for having no exhaust... the 140 some bucks for an external is looking pretty cheap.
Old Jun 26, 2001 | 02:06 AM
Zepher's Avatar
You don't have to cut off the exhaust, you just have to jack the car up as high as possible, take your wheels off, disconnect any brackets that are holding the brake lines to the car so that they don't break which will give you a few extra inches to lower the rear end, take off the panhard bar and the other brace, disconnect the shocks.
When you have the axle as low as possible then push down on the muffler to get it as low as possible, be carefull not to break any welds on the exhaust.
We did this last thursday on my brothers 96 Camaro. Took maybe 4 hours to do everything.
His intank fuel pump doesn't come seperately, you have to buy it complete with sender, list price is $349, I got it for him for $254.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Jun 26, 2001 | 06:12 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
http://members.home.com/syclone/APE/fuelpump.html
I ordered a Walbro High-Pressure 255 ltr/hr pump kit from Ron at Auto Performance Engineering. Cost me $108 complete. Beats the hell out of paying double
http://www.havemann.com/lee/firebird.html
1989 Firebird Formula, WS6 Package
ZZ4 Crate engine, Accel 24 pound injectors, Accel Superram intake, Accel Large tube runners
SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust, Random Tech 3" hi flow cat
700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band, 2200 rpm stall converter
Borg Warner 9 bolt rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's, Spohn subframe connectors, custom chip.
Old Jun 26, 2001 | 07:39 AM
91-ZZ4-Z28's Avatar
I did not say it was a quick job just not hard, even on your first time you can get it done in an afternoon. And you do not have to cut your exhaust you can unbolt you exhaust at the cats and push it back out of the hangers and turn it down and to the side and slide the tank down and to the left.
LeeH what times do you run just interested because we have a very similar set up.
Old Jun 26, 2001 | 08:24 AM
LeeH's Avatar
Engine: 389
Would you believe that I have never taken it to the track? Well, actually, it's been to the track a bunch of times, but that's cause I hang out with a bunch of comp eliminator guys, so every time I am at the track there is a point's meet or something going on.
I am going to the North East Thirdgen gathering in Virginia Beach on July 27, so I will actually get it dynoed and race it there. Which ought to be interesting, cause I have never driven on a track before. Any tips?
Old Jun 26, 2001 | 09:00 AM
91-ZZ4-Z28's Avatar
I believe you I havent made it to a track yet myself, I hope to late this month if I get a good n2o chip burned by then
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
