Speedometer quit working.
Old Jan 21, 2008 | 03:36 PM
landofoz1978's Avatar
Car: 1991 Z-28
Went out to get in the car (1991 Z-28, 305, auto tranny) one morning and when I started driving I noticed that the Speedo had quit working. The dummy light never came on and the odometer is still working. And the speedo was working fine the last time I had driven it. Any idea if this would be a defective VSS? Not sure what it would be. Guess I will take it to the shop if I can't figure out what it is with some help from here.
Old Jan 21, 2008 | 04:42 PM
bruce lamoureux's Avatar
Car: 1991 firebird formula
Transmission: auto.
Axle/Gears: ?
Re: Speedometer quit working.
check your cable and your drive gear in the trany.
Old Jan 21, 2008 | 05:03 PM
Car: 1991 Z-28
I will check the drive gear, and from what I have gathered my car has an electronic speedo and doesn't have a cable.
Old Jan 22, 2008 | 08:56 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Yes your car should have an electric speedo. It doesn't sound like your VSS is bad since it isn't throwin a code up, so the ECM is still getting a signal. I think your gauge is bad, but I don't know how you would go about fixing it without having to replace the whole cluster, I'm not real familier with the 90-92 gauge clusters.
I do think it is strange that your odo is still working though, maybe the needle is just stuck or became detached from the face of the gauge.
Old Jan 22, 2008 | 01:05 PM
Car: 1991 Z-28
Talked to my mechanic today and he also agrees that it is most likely the actual speedometer unit. I am going to take it in and have it checked out here in the next couple of days to find out for sure. Does anyone know if it can be replaced by it's self or do you have to replace the entire cluster also?
Old Jan 23, 2008 | 12:30 PM
Car: 1991 Z-28
Drove the car again yesterday and now the odometer is not working either.
Old Jan 23, 2008 | 12:44 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Cant rack up miles if the speedo isnt working! The two go hand in hand.
Not saying it will work for you but, I once had the similar problem with my RS, only it would come and go. The culprit, the connection at the cluster. Make sure the male wiring connector is fully seated into the female connector on the back of the cluster. It's a free check.
Good luck
Old Jan 23, 2008 | 06:03 PM
Car: 1991 Z-28
How difficult is it to pull the cluster out?
Old Jan 23, 2008 | 09:43 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
i have the same problem with my 91 z28 convertible ..
i took it to the chevy dealer and they wanted $610 to send the cluster away and get it fixed ..
it happens to all of them eventually ... something to do with the resistors and crap on the board ..
but i found that nordskog makes a "direct fit" replacement digital panel .. ordered mine 3 months ago for $462 w/ shipping .. and there just now gettin ready to ship
from what i understand .. our gauge clusters are only 91-92 .. so there is no real big demand ..so they only make a few clusters a year .. but they got a lifetime warranty which won me over ..
if you want to get one i'd call them right now b/c they emailed me saying there almost done building them for this year .. next chance will be mid december this year ..
ill let yall know how it goes when i install it in about a week or so ..
adrian
Old Feb 14, 2008 | 10:28 AM
Car: 1991 Z-28
Ok, I bought a 110 mph speedo on eBay for $15 swapped it out yesterday and everything is working great thanks for all your help on this issue.
Old Feb 14, 2008 | 04:39 PM
Transmission: 5 spd
got my camaro built and all back together ..
its my daily driver now .. fun as hell to drive .. also got the digital cluster hooked up ..
i must say its a REALLY nice upgrade from the stock cluster .. especially for $462
and its very accurate .. i love it and all my friends think its the best thing ever ..
if you have troubles with you guages, i'd recomend getting one ..
only thing is the wait for it, they only make the 91/92 cluster one time a year .. but i think all the other third gen ones are readily available ..
and they got a lifetime warranty
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
