help my tpi is having problems
Old Feb 6, 2008 | 06:46 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
every time i start up my car i have to lay on the gas at about 2,000 rpm or it will die. and it as a nasty idel at stop and serges sometime very bad. am mean the rpm will go up to 2.000 and down to 500rpm on and off and try to die. I took it to some shops one sayed he does not have the time to do a long time repair job on the car. bullshit. and the other said its to old get rid of it and get a wrx. i wanted to punch this a hole. I love my formula no matter what and will keep it for as long as i can. so if anyone can help i would be happy.
Old Feb 6, 2008 | 08:22 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: help my tpi is having problems
It could be your Idle Air Control Valve (IAC). This is what controls the idle. Any decent chilton's or hayne's should tell you how to set it. If not, and you have the factory manual, that will def. tell you.
Old Feb 6, 2008 | 08:26 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
yeah,I had that same problem once.
When I removed the IAC valve,it was full of carbon.
Cleaned it up and all was good.
Old Feb 6, 2008 | 09:03 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
What size of socket/wrench is needed to remove the IAC?
Old Feb 6, 2008 | 09:07 PM
Car: 91 formula
you need a 1-14th socket but the throttle body is in the way to remove it.
Old Feb 7, 2008 | 06:53 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Could also be the TPS. If it was fluctuating or giving a false reading it would cause similar issues.
Old Feb 7, 2008 | 07:37 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Have you pulled the codes?
Old Feb 7, 2008 | 08:04 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Could also be a faulty ECM.
Old Feb 11, 2008 | 07:43 PM
Camaro91z28305's Avatar
I am having a similar issue...however without the huge fluctuation from 500-2000RPM. Pulled a TPS code from the car tried one out off the shelf at work (NAPA) and no change. I am about ready to tackle the IAC valve......This problem comes and goes though, it isn't consistant.
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
