MAF 305 & 350 the same?
Old Aug 18, 2001 | 06:40 AM
bombero437's Avatar
Im having to replace my MAF on my 89 305 TPI IROC 5-Speed. I replaced both the relays and it still runs like crap with the MAF plugged in, but it runs fine with it disconnected. My freind plugged into a testor and it says the MAF is bad, he has a good one from an 89 350 TPI (he thinks it is anyway) will this work on my car? and is there a way to tell which one he has?
Thanx
Old Aug 18, 2001 | 08:39 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It'll work.
Old Aug 18, 2001 | 08:40 AM
bombero437's Avatar
thanx, im gonna get it this afternoon, ill let you know how it turnz out.
Old Aug 18, 2001 | 12:19 PM
87tpi420's Avatar
you did reset the computer right?
disconnect the battery for a minute? just a minor fact that might help
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Old Aug 18, 2001 | 02:14 PM
bombero437's Avatar
no, I did not reset the computer. I didnt know that I had to. does it matter which terminal i disconnect? and for how long to leave it off to reset.
Old Aug 18, 2001 | 09:37 PM
87tpi420's Avatar
just disconnect the neg for a minute or so, the reconnect and drive the car up to temp. then go home and check codes again. if you have the code again...chances are its bad.
http://people.ne.mediaone.net/gdm
Old Aug 20, 2001 | 09:58 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
wouldn't it just be easier to take out the fuse for the ECM for a minute?
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Aug 20, 2001 | 07:47 PM
irocbsa's Avatar
Probably. I do that sometimes.
bsa
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
st.evel07
Aug 13, 2015 06:15 PM
