Walbro 255ltr/hr pump ?Do I need an AFPR?
Old Aug 21, 2001 | 09:43 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I'm putting a 91Z 305 TPI engine in my RS,if I use a walbro 255 fuel pump will i need to use an AFPR.I plan on putting one on later but for now I just need to get the engine in the car and get it running,also is the pump a direct replacement for the RS pump or will i need any additional items.thanks......jt
92RS
Old Aug 22, 2001 | 07:07 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
You can use the stock regulator. And the pump is a direct replacement. Why use the 255, when the 190 should do you fine? Unless you have a power adder going on, too.
Old Aug 22, 2001 | 07:16 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
what kind of power is the 190 good to? The 305 is just temperary..I have the parts car and figured this would be the easiest way to get my RS set up with TPI.Now when I do get a another engine I don't want to have to change the fuel pump again,the engine i'm planning on is in the 400-430hp range.If the 190 will feed it then by all means I'll go with it.Is it cheaper?If not i might as well go with the 255 just in case.....thanks
Old Aug 22, 2001 | 09:34 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Jeremy
I just bought a walbro 255 from APE Ron has the best prices that ive found on them. It was only 97.65 shipped,He sent it to me PM i got it within a couple days.
http://AutoPerformanceEngineering.com
From what I understand the 190 is a good stock replacement.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited August 22, 2001).]
Old Aug 22, 2001 | 11:07 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i went with the 255 high pressure unit because i plan on putting a S/C in next year
APE had it to my door in 2 days for $108
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Aug 22, 2001 | 12:25 PM
RCR's Avatar
RCR
That's why I asked if you were going with something different later. Might as well put the 255 in there if you've got it apart. APE is the way to go. I bought one from Ron a couple of weeks ago. Great guy to talk to. Mine was $114, next day delivery.
Old Aug 22, 2001 | 03:01 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
thanks guys......
Old Aug 22, 2001 | 04:58 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
thanks, the web sight awnsered all my questions but one...wich one do i need the 255 ltr/hr pump kit FPG002 or the 255 ltr/hr pump kit FPG003?
92RS
Old Aug 22, 2001 | 05:43 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
The high pressure one FPG003 would be good if you plan to run over 50psi of fuel pressure or a supercharger. I dont plan on doing either so I bought the FPG002.
Btw... did you get a chance to work on getting the wheel off.
Old Aug 22, 2001 | 07:32 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
thanks,Mike.....your sterring wheel is off the car and ready to go..
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
