4bbl to TPI distributer
Old Aug 28, 2001 | 05:39 PM
v8power's Avatar
I am changing the carb system on my 86 IROC 350 to a stock 88 TPI system
the distributer on it now is a HEI with the vaccum pot the new dist has the external coil (which I dont want)
is there a kit to convert the old dist to the computer controlled advance and what ever else needs to be changed?
Old Aug 28, 2001 | 06:23 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
No kit to convert. Sorry.
I would just look for a factory replacement, the original would be compatable with TPI but since you said it's a vaccumm advance style, it's been changed.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Aug 30, 2001 | 06:51 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You can get the distributor from an 85 or 86 TPI car, those years had the coil in cap style distr.
Just use your old dist as a core to get the new one cheaper.
Autozone has them for $120, $80 if you bring in your old dist.
Just get a new cap, and rotor, new ones don't have those.
Note: normally they only do cores on the same item, so they might not take you Vaccum dist as a core, but you can always try.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Aug 30, 2001 | 07:22 PM
v8power's Avatar
fo you by chance know the engine code i called the parts store and he ants to know
like vin g or h or F or some thing
thanks
Old Sep 1, 2001 | 06:22 PM
Zepher's Avatar
you want the distributor for an 86 Trans Am vin "F". 5.0L Fuel injected.
WS6 Trans Am.
Old Sep 1, 2001 | 07:29 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by v8power:
</font>
Easiest long term plan is getting a distributor out of a 87-92 ish 350 Pick up. Uses a small cap, so getting a good external coil is an easy thing to do.
Different connector for harness, but overall easier to work on.
Old Sep 1, 2001 | 08:54 PM
v8power's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Grumpy:
</font>
I already have a dist out of an 88 I do not want an external coil
I want to convert my vacume dist to an electronic if i can but i think i will just look for a 86 TPI one
does any onw know if the connectors will work with the 88 harness?
Objects in mirror are more stable than they appear
www.members.home.com/v8power
4BBL to TPI in the works
86 350 5spd
E.E.T (Electronics Engineering Technologist)
Old Sep 2, 2001 | 05:18 PM
Guest
Guest
Posts: n/a
The 86 and 88 connectors are different, so you will have to do a little rewiring.
Brcharrelson
Aug 26, 2015 07:47 PM
pimprs
Aug 24, 2015 11:20 PM
86IROC112
Aug 17, 2015 02:00 PM
Dquickshift
Aug 12, 2015 06:21 PM
Sanjay
Aug 12, 2015 03:41 PM
