need help with a cam
Old Aug 30, 2001 | 12:53 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I am sawapping to TPI. I have Edelbrock RPM heads on a 9.5 compression 350ci. It will be backed up by a T-56 with 4.10's in the rear.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
SLP headers, completely done over suspension, black paint with flames, NEW PLAN IN THE MAKING:
BUILD A WILD CHEVY 302 JUST LIKE THE ORIGINAL Z28 HAD
Old Aug 30, 2001 | 10:12 PM
FlashGTA
Guest
Posts: n/a
What kind of help do you want? I do think the 4.10 gears in a TPI car is too steep unless you are running tall tires.
[This message has been edited by FlashGTA (edited August 30, 2001).]
Old Aug 31, 2001 | 07:12 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
well I will have the T-56 in there don't you think that will cut down RPM's alot? I haven't decided on which aftermarket basplate I want but I will have SLP runners ported plenum, and 24lb injectors. what cam should I use for this set-up? Does everyone think that 4.10 are too much even with the T-56?
future mods:
Old Aug 31, 2001 | 08:06 AM
FlashGTA
Guest
Posts: n/a
Unless the SLP runners are fully siamesed then you still have an extremely long intake tract so your torque will still be heavily biased to the lower RPM range and your HP will probably max out at 5000 to 5200 rpm. But I suffered brain fade on the T56, that should allow you to run through the traps in fourth near the peak of the power band. There are a lot of great cams out there for your combo what is the max lift your valve springs allow?
Old Aug 31, 2001 | 08:07 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
.535 is the max lift on the Edelbrock springs.
future mods:
Old Aug 31, 2001 | 12:14 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The 4.10's are short gears. I'd run Drag radials all the time. If you can shift FAST then you should be OK. But that engine is going to wind pu very fast.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum
Old Aug 31, 2001 | 04:14 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
true but the T-56 has a pretty easy first gear don't you think? It is 2.66. if you guys don't think so then I will use the 3.73's sitting in my garage.
future mods:
Old Sep 3, 2001 | 11:31 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
does anyone have a good idea for a cam? emissions are not a concern. it is a 350 I might even port the heads this winter. It is the car in the sig. What do you guys think? I don't mind lopey or what ever I just want to make a lot of power!
future mods:
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
Old Sep 3, 2001 | 11:38 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
This won't be a stock TPI either. It will have siamese runners and an aftermarket baseplate. ported plenum. bigger throttle body
future mods:
Wifes new car:
future mods:
Old Sep 3, 2001 | 05:40 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
anyone?
future mods:
Wifes new car:
future mods:
Old Sep 3, 2001 | 06:17 PM
JETHROIROC's Avatar
ZZ4 cam, LT4 HOT cam, TPIS ZZ9, one of the LPE cams, several from Comp. I would probably go with either the ZZ4 or LT4 since the price is good, but the others will do nicely as well. With your combo, you'll need some good airflow for the LT4 HOT, although you could stuff it in under your carb setup. I'd probably err on the mild side and grab the ZZ4 for around $160 or so. Just my $0.02.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 3, 2001 | 06:49 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Can you give me some specs on these cams? I plan on getting siamesed runners and porting the plenum alot and getting a high flo baseplate like the edelbrock and porting that too. probably port the heads and get a 58 mm throttle body. with 30 lb. injectors. sounds good? What would be the wildest cam to make the most power? I don't know much about the limitations of TPI but i am trying to get it to overcome its breathing problem.
future mods:
Wifes new car:
future mods:
Old Sep 3, 2001 | 07:10 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
oh yeah I need a flat tappet cam
future mods:
Wifes new car:
future mods:
Old Sep 4, 2001 | 06:42 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I am looking at the XE-268 from comp cam. Does that sounds good?
future mods:
Wifes new car:
future mods:
Old Sep 5, 2001 | 02:03 AM
FlashGTA
Guest
Posts: n/a
Yes that would be a good cam. I wouldn't waste your money on a 58mm TB though, it's overkill. If you have to have an aftermarket TB get a 52. The new GM RamJet 502 Big Block makes 502 HP with a little ol 48mm TB just like on a stock TPI.
Old Sep 5, 2001 | 07:11 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
thanks Flash and everyone else for all your help. I saw that in their catalog it said 350 TPI with modified intake runners and exhaust so I figured it woud be good.
future mods:
Wifes new car:
future mods:
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
