OK, I admit to having a vette and sneaking tips from you guys!!!
Old Sep 2, 2001 | 04:50 PM
wordguy's Avatar
You guys seem a little more technical than some of the guys at Corvetteforum
Old Sep 2, 2001 | 04:57 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Hi,
Glad you're on the board, but before they lock this thread for being non-tech, I do have a tech question:
I bought an '86 Vette Coupe L98 but I haven't seen the engine yet, it's being sent directly to the shop. If I gave you the vin number would that help tell you if it is an iron head or am I lucky to have gotten one with aluminum heads? I have the title of the donor car.
Anyway, welcome to the board.
1992 Pontiac Firebird Formula (original 305 TBI) The project has begun:
just purchased 1986 Corvette 350 TPI, Dual fan setup, OEM Posi, GM 3.42 gears and JEGS Ultimate Support Cover for 7.5 rear.
1997 Chevrolet Camaro SS # 379 (1 of 371 Black, T-Top, 6-speed)
1973 Chevrolet Camaro RS/Z28
1969 Chevrolet Camaro SS 350
RIP Dale Earnhardt.
Old Sep 2, 2001 | 05:01 PM
wordguy's Avatar
Unless i'm mistaken all L98 vettes got the aluminum heads.
Old Sep 2, 2001 | 05:18 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I think they started getting aluminum heads in 1986.
92Z28
89GTA
Old Sep 2, 2001 | 05:26 PM
88 IROC BOB's Avatar
Hey Wordguy, I steal ideas from corvetteforum so welcome aboard.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Sep 2, 2001 | 05:38 PM
92 Formula's Avatar
Engine: Twin 454's
<font face="Verdana, Arial" size="2">Originally posted by wordguy:
Unless i'm mistaken all L98 vettes got the aluminum heads.</font>
I have been told that most '86 coupes had iron heads, while the '86 convertibles had aluminum heads. Still, sometime during the latter part of production the coupes switched over to aluminum heads, too. The question I've got, is how can I tell if the donor Vette I have is late enough...without waiting for it to be delivered to the shop. I'm a little impatient.
Old Sep 3, 2001 | 03:26 PM
drive it's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92 Formula:
I have been told that most '86 coupes had iron heads, while the '86 convertibles had aluminum heads. Still, sometime during the latter part of production the coupes switched over to aluminum heads, too. The question I've got, is how can I tell if the donor Vette I have is late enough...without waiting for it to be delivered to the shop. I'm a little impatient. </font>
If you can:
Ask them if the valve covers have center bolts or perimeter bolts; center=alum. and perimeter=iron heads.
86 406
Old Sep 3, 2001 | 04:25 PM
92 Formula's Avatar
Engine: Twin 454's
drive it,
I cannot thank you enough for that answer!! I know for sure it is a perimeter bolt valve cover. So, I unfortunatly have iron heads. Do you know if the iron heads have EGR provisions?
Thank you!!
Old Sep 3, 2001 | 08:31 PM
long&low
Guest
Posts: n/a
HA!!
I've got you beat, I don't own an F-Body or a Vette. My TPI is in an 88 fullsize truck.
*** I Love TPI, It looks so cool.
Old Sep 3, 2001 | 08:44 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The iron heads still have provisions for EGR. With the iron heads the EGR is still taken from the number eight cylinder exhaust header and routed into the back of the intake manifold. If you have any other questions on the 1986 Vette, drop me a e-mail, I might be able to answer them. I just bought a 1986 coupe with iron heads.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Sep 3, 2001 | 09:14 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
<font face="Verdana, Arial" size="2">Originally posted by long&low:
HA!!
</font>
Oops! I'm gonna confess too!
'89 GMC Pickup, 4040# with driver.
383 .030x3.75 Stroke
SRP 11:1 pistons (flat tops)
SLP 51006 Hydraulic roller, 3 degrees adv. built in
in: .495" 270 218
ex: .502" 276 224
TrickFlow 23 degree aluminum heads w/.039 quench
Accel 74197 intake, SLP runners, Ported plenum, Air foil
Huge K&N filter, 3" SS pipe, in and out of the MAF
30# SVO injectors
3.73 gears with 295/50/15 rear tires
Love this board though and I have owned two thirdgens in the last two years. Project cars I sold off after I was finished.
_ ___ _
SMasterson
Old Sep 4, 2001 | 01:03 AM
drive it's Avatar
[QUOTE]Originally posted by bjankuski:
[B]The iron heads still have provisions for EGR. With the iron heads the EGR is still taken from the number eight cylinder exhaust header and routed into the back of the intake manifold.
Ditto the above. Also if you plan on changing only the heads- a "quirk" to keep in mind for compression ratios; the iron heads are 64cc chambers vs alum. head 58cc. The difference was made up on the iron heads by using a thin "metal shim" head gasket, instead of a thicker composition head gasket on the alum. Sorry I don't remember the thickness on the two gaskets.
86 406
Old Sep 5, 2001 | 03:18 AM
92 Formula's Avatar
Engine: Twin 454's
Can somebody give me the horsepower/torque figures on the '86 L98, as well as the compression ratio? I assume 9.8? and 220 horsepower and 320 torque?
Old Sep 8, 2001 | 03:40 PM
BC86TPI-Z51's Avatar
Can somebody give me the horsepower/torque figures on the '86 L98, as well as the compression ratio? I assume 9.8? and 220 horsepower and 320 torque?</font>
I have the late model 86 Coupe with aluminum heads.The HP rating was rated at 235 HP and torque was 330-340.Not exactly sure.
YES guys, the late coupes got the alloy heads as well as the vertibles.
However, KEEP in mind, the 86 cars recieved a front Y pipe with 2 precats on them versus the 85 style free flow Y pipe.This choked back the engine a few ponies over the 85 set up.
The iron head was rated at 230 HP, and 300-330 ft lbs...not exactly sure of Tq figures again.
A free flowing exhaust, some TPI mods and prom work, youll easily get to 250 HP and 350 Tq figures and possibly a little higher.Higher, the rest is up to you,such as cam changes, head work,TPI mods etc.
The compression ratio was rated at 9.0:1 for iron heads and 9.5:1 for alloys.
it may have been a little higher..most of the ratings have been conservative numbers.
Btw Im a Vette guy who comes here too..
I find myself helping more then asking questions.Seems as if on the forum, if I ask a question, most people dont know the answer.I guess its because I ask questions that are very un common to the cars and I already can do 90% of my own work already.Took time but im getting better.
Lucky for me, a few tech heads that know their stuff allow me to email them anytime and they helped me out many times.
1986 Vette Coupe,auto, 357 L98 w/alum. heads,40 over,crane cam,3.73 Gears,The usual Mods..
Had an 86 Bird before..want to get another F car again!
Azrael91966669
25
Jun 20, 2017 04:04 AM
fasteddi
Sep 2, 2015 10:29 AM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 14, 2015 08:25 PM
