85 tpi knock sensor
Old Apr 11, 2008 | 05:55 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
85 tpi knock sensor
does my 85 iroc have a knock sensor?
Old Apr 11, 2008 | 08:55 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: 85 tpi knock sensor
look on the passenger side of the engine infront of the starter, it will have a 1 wire connector, if its not there you dont have one,later jimmy
Old Apr 13, 2008 | 12:11 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
It should. 1985 is the first year that all US emission standard F-body V8 engines shared the same long block assembly(except for camshaft) with flat top 9.5:1 compression pistons that required the Electronic Spark Control system to prevent spark knock.
The knock sensor is located in the passenger side block drain plug hole and the ESC module is next to the brake booster on the firewall.
Old Apr 15, 2008 | 10:19 PM
im seeing the same part# for both 305 and 350 85-89? are they the same?
Old Apr 16, 2008 | 12:13 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
knock sensor to 305 and 350 is different..
and all TPI vehicles has to have an knock sensor. The ESC module is also different on 305 and 350..
tpiparts have them both.
85-89 TPI knock sensor 305 : http://tpiparts.net/inc/sdetail/468
85-89 TPI knock sensor 350 : http://tpiparts.net/inc/sdetail/429
85-89 TPI ESC Module 305 : http://tpiparts.net/inc/sdetail/1488
85-89 TPI ESC Module 350 : http://tpiparts.net/inc/sdetail/1487
Old Apr 16, 2008 | 12:56 AM
what would be the outcome of me running the lb9 knock and ecs till i can afford l98 stuff? anyone willing to get rid of these items?
Old Apr 16, 2008 | 01:33 AM
Theking's Avatar
Car: 1989 IROC-Z
If you got and 305 engine you have to use an 305 sensor and module
and if you have an 350 engine you have to use an 350 sensor and module
becuase they are tuned/made for that spec. engine size. it dosnet work with and 305 sensor on a 350 engine.. so if you got and 305 engine, but the 305 ones, and if you got the 350 buy the 350 stuff..
Dosent work between each other.. you can brake some stuff if you use the wrong ones..
EDIT: and on tpiparts, its the same price no mather what engine size you have...
Old Apr 16, 2008 | 03:37 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
If you go to Rockauto.com and search knocksensor and esc module to -85 tpi,you find that 305 and 350(vette) have same partnumbers.
Old Apr 16, 2008 | 10:25 AM
im swapping my LB9 out for a 350
Old Apr 16, 2008 | 01:44 PM
this is like most searches iv done
http://cgi.ebay.com/ebaymotors/85-89...3756.m20.l1116
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
