Do you think this is a good cam for this combo?
Old Sep 30, 2001 | 07:40 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Edelbrock 6085 heads with Comp Cams 08-304-8(210/220 .500/.510 112). Basically with a LTR setup- aftermarket base,SLP runners, 52mm throttle body,ported plenum,headers. Would this be a good cam or would you suggest another?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Paxton SN92
Old Sep 30, 2001 | 07:45 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Oh yeah the engine is a 350 .30 over.
Old Sep 30, 2001 | 07:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
With TF Heads and same intake I went with a 218/224 497/502 112 Havent ran the engine yet though.
Old Sep 30, 2001 | 07:59 PM
Jason M 91Z's Avatar
Nah I wouldn't run it. I'd look at the comp 264HR for your application. 212/218, .487/.495. With 1.6's, lift increases to .520/.528. I wouldn't suggest the bigger XR269HR for an LTR setup, but it will work well also. Trax ran that cam to a 12.2 with AFR 190's. If you see yourself upgrading intakes soon, you may want to look at the XR269 or XR270HR.
ADD: You can have Comp grind a custom cam. I'd have the 264HR or 269HR ground on a 114LSA and you'll have a nice cam in that 355!
-Jason M. 1991 Camaro Z28
[This message has been edited by Jason M 91Z (edited September 30, 2001).]
Old Sep 30, 2001 | 08:04 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
TRAX ran the XR269HR with the LTR setup to a 12.2?
Old Sep 30, 2001 | 08:07 PM
Yeah, had the heads for it too though...
Old Sep 30, 2001 | 08:11 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I'm just looking to run mid 12s with the LTR setup. So you think I can get that with the 264HR cam and my combo?
Old Sep 30, 2001 | 08:15 PM
I doubt it. You'd need better heads and the 269 for mid 12's probably. Port the heads and run the 269HR and you'll probably make mid 12's with tuning.
Old Sep 30, 2001 | 08:18 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
thanks
Old Sep 30, 2001 | 08:23 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I checked on that 269 cam and was wondering what was thE part number cause thet got one CSXR296HR AND lt1XR269HR?
Old Oct 1, 2001 | 01:52 PM
The one with the LT1 prefix is for LT1 engines which require a longer dowel pin to engage the water pump and optispark distributor. You need the first one.
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
