Super Ram and Wiper Motor Prob.....tried flipping mounts!!!
Car: 89 IROC-Z
Engine: 383
Well I'm running into the normal wiper motor/plenum issue, but I flipped my wiper motor mounts around and it's still not even close. Anyone have any other suggestions? Also has anyone ever had to grind the bottom of their runners to get the bolts to line up right??? I did and it was a pain!!!
Riccioli Performance Motorworks
--RPM Racing--
Getting there.....383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now let's pray it runs when it's all back together!!!!
--RPM Racing--
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I had to take my rubber mount off of my wiper motor. I don't think flipping them will help. Try taking off the one closest to the corner of the intake. The bottom leftmost one.
Car: 89 IROC-Z
Engine: 383
It's still too close by atleast a half inch with no rubber mounts!!! Now what the hell am I going to do?? I do need functional wipers because I will drive the car everyday when I'm finished.
Car: 84z28
Engine: chevy 388
i had to cut my washer motor out it seems they
moved it to the washer bottle so i guess whin linginfelter
desiged it he did for a corvett or newer camaro.
you can see pics of it at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Car: 89 IROC-Z
Engine: 383
My washer pump is in the bottle.
--RPM Racing--
--RPM Racing--
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
This is kinda weird b/c mine fits w/ no problem and I'm using the rubber mounts. Maybe you should try getting some new motor mounts???
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
Dan
Car: 89 IROC-Z
Engine: 383
New mounts will definately not work because I already tried it with no mounts at all and it won't fit. I have a feeling I'm gonna be screwed here.
I know this isnt the right way to fix it but...
I put an 1/2" aluminum spacer plate under the tranny mount, which raised the trans/rear of engine enough so I could plug the pigtail into the wiper motor.
Hope that works for you.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.47@129 1.55 60FT. ON MOTOR - ET-STREETs w/MUFFLERS
14.1@ 98MPH
OTHER RIDE
Car: 89 IROC-Z
Engine: 383
Hey that's a pretty good idea. I'll have to try that if I can't come up with an alternate for a narrower wiper motor. Did you make it yourself or have your machine shop do it? Where would I go about getting a piece of aluminum like that?
I think a buddy of mine got it at work, but I usually have some scrap
metal around anyway. If not try a local metal yard / steel supply, they
have all kind of metals - new and used. Yea it can mess up the driveline
angle, but it seems to be OK on mine, and I'm making an adjustable
torque arm for it so atleast I'll be able to fix the pinion angle. I dont know
how critical it is to keep the whole driveline in a perfect straight line, but
when your suspension moves it gets a little out of line anyway. So I think
thats OK, aslong as you get the right penion angle and the car hooks!
Unless your makin over a 1000hp I dont think it maters. Mine will be
a 450hp 383, it should work.
14.1@ 98MPH
OTHER RIDE
14.1@ 98MPH
OTHER RIDE
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Anyone know of a shorter wiper motor? I have the '89 style with the pump in the reservior already, and my motor won't fit even without the rubber isolators.
I'm wondering if there's another application that I can use that's thinner (anybody know about the 4th gen ones?) or I might have to resort to surgery on the motor I've got...
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Mine fit no problem with a 1987 wiper motor, about 3/4" clearance. Maybe you can swap motors.
ambainb
Apr 25, 2016 09:21 PM
