Does anyone make an alternative to the MR/SR intakes?
Old Sep 19, 2001 | 10:51 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Hi everybody,
My question is about the intakes for TPI cars. Does anyone make a Carb type manifold with some kind of adapter to use a throttle body & the 8 injectors with a fuel rail already installed? The reason that Im asking is because the Miniram/Superam set ups are way overpriced! I need a combo that allows the motor to rev to at least 6500rpm with ease.
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Sep 19, 2001 | 11:13 AM
Drakar's Avatar
Port and Siamese your base and plenum and get SLP runners and do the same, that should let it rev higher. but if that doesn't work and MR/SR are over priced you might be looking at a carb.
my .02
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Old Sep 19, 2001 | 11:39 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Accel makes an intake called the Pro-Ram that is excatly what you are talking about, it's a single plane intake that has been fitted w/ injector bungs. For a TB you have serveral options. The cheapest would be to take a 454TBI unit and gut it of everything except the TPS and IAC . Bam, instant throttle body w/ IAC and TPS for your computer. You can also buy elbows that are made to mount GM or ford TBs to the carb flange. Or you can buy a high dollar fancy billet carb baseplate style TB.
You also don't have to buy the pro-ram, you can convert any single plane intake to FI just by welding/drilling the injecor bungs and fuel rail mounts. Even getting one custom done will be significantly cheaper than buying a MR/SR.
As for a comparison, our own guido is currently running a MR, but he's thinking of changing to a single plane style. Look for some back to back runs (the beauty of the MR, you can swap intakes at the track, in a reasonable amount of time, try that w/ a SR, lol) next year to see which truly is the best.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Sep 19, 2001 | 12:11 PM
86Tra/maro's Avatar
Any links to these intakes? How do they perform in the real world? whats the prices? & are they worth it?
Old Sep 19, 2001 | 10:54 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
here ya go.....
you go fast now
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Old Sep 20, 2001 | 03:07 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I have a cost efficient alternative to the Miniram. Just swap that old non-breathing and heavy TPI intake for a factory LT1 intake. The LT1 weighs half of the TPI BTW.
You say it's impossible? Won't bolt up? Well your right but ANYTHING is possible when cost is a factor. Here's some of the biggest issues you're going to run into and a quick explanation of what to do about it. Look for a tech artical soon.
There are several problems with the STOCK LT1
intake but the ports and coolant passages are not one of them. What I did
before I started was get a cheap $6 intake gasket from DAP and just layed it
on the intake (already off the car), everything was perfect except for some
of the mounting holes, the 4 corner ones were good. No problem, I took the
gasket as a templet and drilled the new holes in the intake, no more
problem.
Problem #2, in case you havn't noticed there's no rear distributer on a LT1.
I had to drill the hole for it, warning-this hole must be in perfect
location. I used a old TPI base and made an aluminum templet utilizing the
rear two mounting holes to locate the dist hole. Distributer must be shimmed
about 1/4" higher due to the shortness of the LT1 intake. Also must use the
small HEI distributer with remote coil found on 1987-later.
Problem #3, No front coolant passages to return to the radiator. Well, I
just drilled and tapped two 3/4" heater nipples vertically where the coolant
would normally exit the head. I will run 3/4" heater hose to a remote
thermastst housing I found on-line. it will be mounted on the fenderwell. It
will use the same outlet neck and return to the radiator as it should.
Problem #4, must have custom fuel lines made to attach to the fuel rail of
the LT1. About $40 if you supply the ends. Available from Pep Boys.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 20, 2001 | 04:27 PM
Ed Maher's Avatar
Car: 04 GTO
Wow John, great work. What did you do for a dist. hold down bolt? I guess the easy way would be to drill/tap a hole in the intake and use washers as a base to get the height of that set right?
If that really works (and i see no reason it wouldnj't sinc ethe ports line up), then the only tricky part to stop anyone from doing this would be the dist. mounting issue. If you could mock up an easy to use jig/template i'm sure a lot of people would use it, and could even make you a few bucks for your idea.
...ed
Old Sep 20, 2001 | 04:53 PM
u r sofa king we tah did's Avatar
so there is a coolant passage on the LT1 intake, just not a return to the radiator?
Old Sep 20, 2001 | 05:37 PM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by u r sofa king we tah did:
so there is a coolant passage on the LT1 intake, just not a return to the radiator?</font>
No, there is no coolant passage in the intake. The coolant normally enters the intake from the first port on the head forward. The intake is blocked off. I drilled and tapped for a vertical heater fitting on each side and will run the 3/4" heater hose to a remote thermostat housing then to the radiator. You can see one fitting in the pic above drivers side forward. Here's a pic of the housing.
86 Camaro Sport
My Camaro Project
Old Sep 20, 2001 | 05:48 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
drakar, I believe your sig says that Honda engines rock. Did I miss the sarcasm or did some computer hacker try to frame you.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Sep 20, 2001 | 08:02 PM
Guest
Guest
Posts: n/a
Not that the miniram has one, but I assume the stock LT1 EGR has to disappear for this to work.
Old Sep 20, 2001 | 11:05 PM
cy Z28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by madmax:
Not that the miniram has one, but I assume the stock LT1 EGR has to disappear for this to work.</font>
...And,
Old Sep 20, 2001 | 11:06 PM
Tas's Avatar
Tas
Holley does. $255 for the bare intake from summit. 4x cheaper than TPIS!!!
http://www.holley.com/HiOctn/ProdLin...901-101-1.html
There is even a Vortec version for about $435, almost the same price as a Ram Jet bare intake.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited September 20, 2001).]
Old Sep 20, 2001 | 11:10 PM
cy Z28's Avatar
This does definatly get the ol gears turning.
Cody "cyZ28" Young
Old Sep 20, 2001 | 11:40 PM
Tas's Avatar
Tas
I've also seen thermostat housings in the top coolant hose like on the Dodge v8 trucks
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Old Sep 21, 2001 | 06:05 AM
ImportsRsloths's Avatar
John you should seriously make a tech article with all that stuff and pictures etc.... thats really cool, id really consider doing that if you made a good tech article with pictures.
Old Sep 21, 2001 | 07:11 AM
Engine: 4.0L
Absolutely the EGR must disappear. Due to the distributer. Now if you went distributerless ignition well........
86 Camaro Sport
My Camaro Project
Old Sep 21, 2001 | 10:45 AM
Guest
Guest
Posts: n/a
I wonder if one of those offset distributors I have seen would clear everything.
Old Sep 21, 2001 | 12:20 PM
i was thinking about making an aluminum box out of some sheet metal, and cutting the runners in half and rewelding the bolting part of the runners to make my own home made super ram.
Old Sep 21, 2001 | 12:24 PM
can anyone with a super ram go out and take some measurements of the box for me?
Old Sep 21, 2001 | 12:40 PM
Guest
Guest
Posts: n/a
i was thinking about making an aluminum box out of some sheet metal, and cutting the runners in half and rewelding the bolting part of the runners to make my own home made super ram.</font>
Thats how it was originally designed.
Old Sep 21, 2001 | 02:00 PM
Tas's Avatar
Tas
There are also distributorless ignition systems. One company is Electromotive.
Old Sep 21, 2001 | 03:00 PM
Engine: 4.0L
Here's their website. VERY EXPENSIVE.
http://www.emi.cc/
86 Camaro Sport
My Camaro Project
Old Sep 21, 2001 | 05:10 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
John that is awesome. everyone said it cant be done or would be a waste of $ and time.
Im in the process of tryin to make a polly or carbonfiber SuperRam (runners and box). I have all the suplies at work.( the ability to make a mold, etc.)
My biggest problems are
What to do about all the bolt holes. i could sleeve em like the LS1 maybe.
anyways, GREAT JOB. keep everyone posted how it works.
Old Sep 21, 2001 | 05:31 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I am very interested in hwo your home made intake is going. You get this thing to run right, you better get the rights to it. The sheet metal would be so cheap you could dominate the market.
Old Sep 21, 2001 | 11:11 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
VERY NICE. Very, very nice work John.
Looks like someone's gonna put TPiS outta buisiness...hehehe
Damn, I know where I can get an LT1 intake setup too...use the LT1 injectors and put it on top of a 327 or an L98 with a 52mm TB and let it rock...oh yeah, baby, oh yeah. 400? We'll save the SR for that.
Wonder what that would do for a 305 with Vortec heads and a ZZ4 or LT1 cam?
I gotta try that when I find another LT1 intake base...now maybe he'll find a way to make LT1 heads for L98's Looks like you proved everyone wrong, good job!
Old Sep 23, 2001 | 08:27 AM
ttt
Old Sep 23, 2001 | 09:32 PM
Tas's Avatar
Tas
dhirocz, you can put LT1 heads on a L98. There is a tech article on my website. Its not worth paying someone to do though.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Old Sep 23, 2001 | 11:06 PM
cy Z28's Avatar
I looked into this and even with my machine shop connections it would be about $1000 to have it fabbed up to work. You can't just build a box, you must radius the inlets and do some interior resonance work. If it's just a shoebox with holes you'll go nowhere fast.
Old Sep 24, 2001 | 01:46 PM
dhirocz's Avatar
Damn, that's pretty cool. First I see a post on how to put an LT1 intake on a standard SBC, then LT1 heads onto a SBC. Anyone do both? If that's all that's required, hell, I had an LT1 longblock I just got rid of (damn) but I'm gonna buy a '84 S-15 for a daily driver, clean truck...when the Camaro get's running I'm gonna drop a low-buck TPI setup into it, I have everything to build a shortblock or Vortec longblock, I'll have to look into this...thanks man
The nice thing about it is I have all the resources to do that work myself...just plug two holes, fix up the coolant passages to the intake and drill a hole for the distributor. I wouldn't even have to mess with bolt hole angles. Then fab in a thermostat adapter and were ready to rock...
[This message has been edited by dhirocz (edited September 24, 2001).]
Old Sep 24, 2001 | 02:24 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Check out my intake setup...
Link is in the signature....
13.3 @ 101.3MPH 95 degrees and 95% humidity w/ no tuning on motor
Sportsman II, Gear drive, Perf. Res. chip, SLP 1 3/4" headers, Edelbrock muffler, Trans-go stage 3, Vigilante 9.5", Functional Ram Air hood, SLP roller cam, 24lb ADS injectors, AFPR, 3.45 gears, Stealth intake, 58mm setup, Spohn suspension, and other goodies...
raven
Custom EFI Intake Setup
Old Sep 27, 2001 | 02:14 PM
C h r i s's Avatar
It looks like a low cost/high performance alternative has been found. You can either use an LT1 intake with the mods John has done or the Holley intake with a gutted 454 TBI. The only snag I have is getting a computer & harness to run the setup properly (my car currently has an RPM intake/Road Demon Carb). I don't have the required eprom burning knowledge or tools . . . yet.
This is very good progress.
Chris
'78 Malibu
'68 Chevelle SS396
Old Sep 27, 2001 | 02:37 PM
Engine: 4.0L
Completed picture of the LT1 intake swap on a Gen1 SBC.
86 Camaro Sport
My Camaro Project
Old Sep 27, 2001 | 11:49 PM
dhirocz's Avatar
Nice...how's it run? Keep us posted
Old Oct 1, 2001 | 06:50 PM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
Good job man. You have figured out a very cost effective alternative to a miniram
If I ever swap to TPI I'm definately gonna use a LT1 intake.
Old Oct 1, 2001 | 07:41 PM
86Tra/maro's Avatar
When U performed the modification on the manifold would u say that it was pretty easy, medium or hard & if I were to send u a manifold how much would u charge to do it up
njdaewoo
Old Oct 1, 2001 | 08:14 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Here's one
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old Oct 2, 2001 | 12:57 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by 92 RSS:
Here's one
</font>
holy schnikes...WHAT IS THAT????
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Oct 3, 2001 | 02:00 AM
89ProchargedROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by fly89gta:
</font>
um......its a small block chevy with a street and performance intake and trickflow twisted wedge heads
anymore questions class?
Old Oct 5, 2001 | 03:24 PM
fly89gta's Avatar
Car: 2018 Camaro SS
<font face="Verdana, Arial" size="2">Originally posted by 89ProchargedROC:
</font>
thats happy nice
Old Mar 8, 2002 | 10:45 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
John,
I love the idea of adapting the LT1 intake but the EGR is a must in my state. I kind of wonder if it could be adapted. I guess with a little engineering it could possibly be done, although you have already done a lot with this system. I think this is what hot rodding is all about. Evaluate, Adapt, and Overcome.
Old Mar 9, 2002 | 07:09 AM
  #42
Engine: 4.0L
Originally posted by 92BLKL98
John,
It would require a lot of thinking and design but yes, I'd say it might be possible to use some type of REMOTE EGR on the conversion.
Old Mar 10, 2002 | 11:11 AM
  #43
Beefy89's Avatar
Theres the new Holley Stealth Ram manifold.Do a search to find pictures,or go to Holleys website and look under "whats new".The local Holley dist. here told me $265 for the manifold and $155 for the fuel rail.He was told by Holley it would take about 3 weeks to get it
RazorN8
Jan 7, 2022 11:44 AM
dutch930
Sep 11, 2015 06:58 AM
86White_T/A305
Aug 17, 2015 12:16 AM
kyle5647
Aug 15, 2015 11:56 PM
