Intakes,Runners & Manafolds
Old Oct 17, 2001 | 07:47 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
I plan on upgrading my intake
system,ie manifold base,runners,
and throttle bodies.Which ones
will bolt up with out being a
pain in the *** .What about
headersI want to use SLP headers
has anyone tried them.By the way
I have a 92 Z28 with 350TPI A4.
Thanks to all
Old Oct 17, 2001 | 07:53 PM
age's Avatar
age
Car: 1992 Z28 1LE
I think the Edlebrock base is pretty good... they had drilled the bolt holes (to the head) to fit either the pre-87 or post-87 heads.. also, there was a lot of extra material that I could do port work with (as compared to stock).
I also have the BBK/Edlebrock 52mm TB that I have no complains with.. EXCEPT that the TB gasket that came with it was for the stock 48mm TB. So, if you do get the 52mm, pay attention to the gasket.
I am using the Accel LTRs, and those were a bit of a pain, because you can only put them on/take them off with the valve covers OFF.. we weren't prepared for that, and thus it became the "black sheep" of the 3 aftermarker intake pieces that I have.
Old Oct 17, 2001 | 08:47 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have the Edelbrock intake, I like it. I also have SLP runners and headers. I like them also.
I got the intake new and bought the runners and headers used to save some cash.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 18, 2001 | 12:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Base: they are all the same to install so get the cheapest one, I think that would be accel/edelbeock.
Runners: I cant remember that installing them would caurse any problem. The most popular is the AS&M and SLP runners. Do a search and you will find alot of info about them.
Headers: SLP are the best says many people, but expensive. When tou install them you'll have to lift the engine a little bit.
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Oct 18, 2001 | 02:21 AM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
installed slp headers without touching a thing. slipped right in!!!
86 305 TPI
700R4
3:42 axle
4 wheel disc
-Summit cam .442" lift
-Summit chain/roller
-Summit tranny cooler
-WORLD S/R Torquer 305 heads w/ LT1 springs
-High pressure oil pump
-Hypertech Airfoil
-SLP 1 5/8" headers
-CatCo cat.
-Flowmaster 80 series c/b
-Taylor Spiro-Pro 8mm
-Bosch Plat. plugs "hot"
-Indexed plugs
-K&N Air filters
-Trans-Go shift kit
-Removed AIR
-180 Thermostat
-T/B coolant Bypass
-All sensors replaced
-Custom Ram-Air
-Poly motor mounts
-Manual fan switch
-Newly Lowered!!!
Eibach Sportlines.
soon...
125 shot, slp runners, perf. chip, ported plenum
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6820.
Old Oct 18, 2001 | 04:35 AM
82resto's Avatar
Installed the SLP headers without touching a thing?? You're definitely alone on that one...
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Oct 18, 2001 | 11:01 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the edelbrock base and love it I also got the AS&M Runners. They bolted up ok but the inside bolts for the runners were a tad off. I have to enlarge the hole on the baseplate to get the bolt to slide in and to thread it in. Also I could only bolt up the runners with the valve covers off.
Old Oct 18, 2001 | 04:40 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
yea, i must have some special iroc or something where they made more room for headers. or maybe i don't and people just complain too much.
Old Oct 18, 2001 | 09:30 PM
Rob P's Avatar
Engine: ZZ4TPI
I moved the steering shaft just to make installing SLP headers (1 5/8") a little easier. Other than that, I moved nothing. They slipped in with little effort.
Rob P
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
