Whos got the cleanest...
Old Oct 24, 2001 | 02:27 PM
HondaHunter's Avatar
i'd like to see some pictures of peoples tpi car's engine compartments. i was wondering who had the cleanest best looking tpi engine setup. i'm currently in the process of doing a full engine swap from an 87 t/a to an 84 firebird. i was wondering about how long would you estimate it would take, i'm switching the engine tranny rear end, and suspension. what do you guys think?
Old Oct 25, 2001 | 01:38 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
Probably not the cleanest but hey, they're good pictures. You keeping the emissions junk?
Jess
Old Oct 26, 2001 | 11:37 AM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
Heres a pic of mine. I ditched the AC and smog equipment. Next think im going to do is bypass the heater valve and get a non AC heater box.
Old Oct 26, 2001 | 11:49 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
This is with a NON AC box and the heater valve removed.
Old Oct 26, 2001 | 01:00 PM
leirch's Avatar
Here you go.. you'll have to copy and paste it.
http://www.geocities.com/leirch_/tea...1/PA170002.JPG
Old Oct 28, 2001 | 11:21 AM
cobrakiller1989's Avatar
Here is mine...Its not that clean right here, but it looks better when i clean it
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback being installed next week
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
Old Oct 28, 2001 | 11:56 AM
91-ZZ4-Z28's Avatar
http://www.fuelinjectedpower.com/db2...mages/pic4.jpg
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Oct 28, 2001 | 12:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It still looks cluttered but,, it is clean.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 28, 2001 | 01:00 PM
Vader's Avatar
I'm not sure what you mean by "clean". Either cleanest, or most naked. This one is fairly clean, but cluttered (bone stock look):
MikeInAZ has an engine compartment that is suitable surgical preparation, but the "table" would get a little uncomfortable. Unfortunately, some of the links on his site aren't working for me right now.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 29, 2001 | 02:58 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Here it is, minus all smog pump junk but keeping the luxuries such as AC and heat.
91 Z28
Come see The Vicious...
Old Oct 29, 2001 | 10:20 AM
Adam62083's Avatar
Old Oct 29, 2001 | 12:01 PM
leirch's Avatar
Here you go. Its lacking something..
Oh yea, the engine ;D
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Oct 29, 2001 | 12:19 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine is not filthy, but..
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Oct 29, 2001 | 04:35 PM
Mojo's Avatar
Hope you don't mind that it's a Vette instead of a thirdgen... It's still a TPI motor, the components are the same!
408cid 1985 Corvette
http://www.mojosgarage.com
Old Oct 29, 2001 | 07:24 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
A hint if I can offer to those looking for a clean engine bay.
Go to GM and buy a new coolant overflow bottle and a new windshield washer bottle. They both go ALONG way to making that engine bay look clean. The best part, they are cheap.
Mark.
Old Oct 30, 2001 | 08:50 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
not Perfect but really nice:
<img border="0" src="http://www.usol.com/~okfoz/images/engine/87TPIengine.jpg" width="448" height="300">
John
Old Oct 30, 2001 | 09:08 PM
okfoz's Avatar
So, you wanna do a Swap to TPI? Read how I did mine here, it might have some useful pointers..
Click Here:
<a href="http://www.usol.com/~okfoz/modification/tpiconversion.htm">TPI Conversion</a></p>
Hope it's a help
John
Old Oct 31, 2001 | 02:04 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I'm not sure if this is going to work or not since it is a geocities site and they usually don't like hosting pics for other websites, but here goes:
It is fairly clean.... I have cleaned it up more since this picture was taken (Aug 2001) but it is a race car (I wish....lol) first, show car .... a distant second... hehe... ........ It was a V-belt setup so when I extracted the emissions control devices and (most of) the A/C it really cleaned it up... Now why in the he11 would I go to a serpentine setup?? I just don't understand why people do that 'mod' ..........
Now - if I could just find an A/C delete heater box!! ....... (hint: if you know of one or have one, email me!)
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
[This message has been edited by Matt87GTA (edited November 05, 2001).]
Old Nov 1, 2001 | 12:19 PM
BlazinOR's Avatar
http://www.blazzinor.rockcrawler.com...w_complete.jpg .........or [URL=http://www.blazzinor.rockcrawler.com/images/tpi_406_cropped_on_engine_stand_small.jpg]http://www.blazzinor.rockcrawler.com/images/tpi_406_cropped_on_engine_stand_small.jpg[/UR L]
'79K5 Blazer with 406TPI
[This message has been edited by BlazinOR (edited November 01, 2001).]
Old Nov 1, 2001 | 05:43 PM
nblanchard's Avatar
Hey... I would have liked to post a picture.. but how do i do it?
Old Nov 4, 2001 | 02:26 PM
Mike B's Avatar
<font face="Verdana, Arial" size="2">Originally posted by nblanchard:
Hey... I would have liked to post a picture.. but how do i do it?</font>
https://www.thirdgen.org/messgboard/ubbcode.html
Old Nov 4, 2001 | 02:30 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Nice setup Mojo. Maybe I'm confused but why does your super ram look like that on top?
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Nov 4, 2001 | 08:10 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
heres my setup
you can check out my site at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
[This message has been edited by DARCOM (edited November 04, 2001).]
Old Nov 5, 2001 | 10:48 PM
David 91RS/Z28's Avatar
With stock TPI on the 305...
With an SR atop a 355...
David Tuschhoff
1991 RS/Z28 Camaro
FI 355ci NA SBC V8 M5.
12.47 @ 110.7mph 1.80 60'
Best mph of 111.6.
My f-body page!
[This message has been edited by David 91RS/Z28 (edited November 05, 2001).]
Old Nov 6, 2001 | 12:12 PM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ions91Z28:
</font>
Thanks!
I bought the optional billet plenum lid and polished the whole thing. The billet lid is pretty much a flat slab of billet aluminum.
Old Nov 6, 2001 | 01:18 PM
ONEFORMULAOVERALL's Avatar
http://wsphotofews.excite.com/025/wh/x1/53/qB36802.jpg
http://wsphttp://wsphotofews.excite.com/021/KN/eZ/6F/qQ39730.jpghotofews.excite.com/014/EW/t2/8e/qU54982.jpg
http://wsphotofews.excite.com/014/Qu/3E/IV/qM50283.jpg
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,L-98 ALUM. HEADS PORTED CRANE AFPR.45PSI,SMOG PUMP GUTTED,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 DUMP
MSDDIST,6AL,TAYLOR WIRES
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.23 AND MOSER AXEL SPLINES CRYGO FROZEN,TUBE FRAME CONNEC,EIBACH PRO.,HOK.LOWER ARMS,PAN,TQ ARM,ALUM. DRV.SHAFT.
PST KIT.1LE BRAKE KIT CROSSED DRILLED ROTORS MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 107.75MPH
[This message has been edited by ONEFORMULAOVERALL (edited November 06, 2001).]
