Lifting out a TPI motor????
Old Nov 10, 2001 | 10:58 AM
Fastcamaro87's Avatar
ok heres what i need to know, i am currently changing my oil pump, and i have to lift the motor an inch or two to get the pan out,
1. Can i lift the motor by putting a steel cable underneath the plenumso that it would be run underneath then hooked to the hoist, and lifting there, bad idea or no?
I want to avoid having to remove my plenum and runners, since i dont want to have to replace the gaskets.
2.Also where else could i mount the cable to lift the motor. thanks
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Gutted Cat, Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 10, 2001 | 08:34 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I wouldn't advise that, I don't think the runners would survive.
I'd probably pull the end bolts on the intake manifold, and bolt down using your favorite homemade loop. Get longer bolts...depending on what you plan to mount in those hole to pull from...1/e if you fab up a loop from 1/4inch plate, then use 1/4inch longer bolts.
Old Nov 10, 2001 | 10:02 PM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
I always had good luck using opposing exhaust manifold bolts also. Just a thought for you. Jeremy
Old Nov 11, 2001 | 04:18 PM
crucial's Avatar
Or take out one of the bolts in the driver's side accessory bracket and put a long grade 8 bolts in it and put in another bolt at the back of the head on the passanger side.
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, aluminum driveshaft, WC 5-speed etc
Old Nov 11, 2001 | 04:43 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Use the holes in the back of one of the heads, and one of the holes on the front of the opposite cylinder head. DO NOT lift using any of the intake runner tubes.
Old Nov 11, 2001 | 11:07 PM
thanks for the replies guys, i am going to use the accesory bolt holes in the heads to lift it up.also, i removed the A/C and im putting in headers, anyone know if i can get a power steering bracket from a non A/C car or does the bracket thats on there come apart?? thanks again
87 IROC-z 305 TPI
Old Nov 12, 2001 | 02:42 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Not saying it isn't possible - but I had no luck lifting the engine up enough to get the oil pan off with the engine bolted to the trans, even when the engine was stripped to the bare block. There was something above the trans that started making *cracking* sounds I was not comfortable with, so I stopped. I just needed to replace the oilpan gasket though, so I bought a one-piece rubber gasket and just slipped it over the pan. That way I didn' need to take it all the way down...
All Im saying is just be careful when jacking it up with all the stuff in. You will for sure have to lift out the distributor though..
Ken
1986 IROC-Z Conv't
- White Gauges, 17x9.5 TT II rims w/275/40x17" F1s, 1.5" Jamex Lowering Springs, BMR stb, Lakewood APR, PST suspension parts, Edelbrock Trailing Arms, KYBs, Edelbrock RPM Cat-Back, Edelbrock JHC Headers, Catco, World Products Heads, CompCam, SLP runners, Ported Plenum, K&N, Airfoil +polished/billet dress-up stuff
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Nov 13, 2001 | 01:58 AM
well i put the oil pump and a new gasket on today, didnt have to remove the distributor, just the two motor mount bolts and the one that holds the trans to the crossmember. after that the motor lifted up just fine, i also installed some headers while i was at it
87 IROC-z 305 TPI
Old Nov 13, 2001 | 06:13 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
About the Power Steering bracket setup for your V-belt system:
That bracket system will come apart and allow you to have just the power steering pump and it's bracket on the engine. The non-A/C car bracket will be a little different and cleaner looking (if you can find one) but you can get all of the A/C bracketry off if you take your time and examine how each bracket is bolted together. I can't remember the exact parts that need to be removed or the order in which they need to be removed, but if you look at the pics of my engine bay at my website, you might be able to get ideas on what to do. The link is in my sig.
Good Luck!
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 13, 2001 | 07:52 PM
i removed the AC and kept my power steering succesfully, will the PWR strng bracket from any late model non AC small block work?
87 IROC-z 305 TPI
Gutted Cat, Dynomax Headers & catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims.
406 siamesed TPI in progress
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
