Turbo?????
Old Nov 17, 2001 | 02:11 PM
WS6Formula350's Avatar
Turbo?????
I have been looking around on the net for a turbo kit for the tpi and i have not found. I know that one is made for the LS1 but like i said i haven't found one for the L98. Can anyone help???
Old Nov 17, 2001 | 04:00 PM
crucial's Avatar
Umm.... it's probably because nobody makes one ? Try the power adder board.
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Old Nov 20, 2001 | 10:32 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
They do not exist. There have been rumors of Gale Banks getting back into it again. He made a kit for the 82-84? F-bodies. Its all custom work at this point in time. Do LOTS of research.
Old Nov 20, 2001 | 11:26 AM
nblanchard's Avatar
I have a 1988 issue of High Performance Pontiac magazine, Pontiac played around with an '88 Trans Am 5.7L L98, it had a twin turbo setup. I tried to dig for more info, but I came up empty handed. I really don't want to do the turbo set-up, so I kinda stopped looking. You don't NEED a kit per say.... You can get custom tubes bent, custom headers.. etc.
I will scan the article if you want to get the info. The setup actually looks easy to copy. Looks like they simply flipped the exhaust manifolds upside down, had an adapter bolted/welded to the manifold outlet, bolted on the turbo right on the adapter, then ran the tubing.... quite an easy setup. The picture tells a thousand words... I'll try and get a good scan of it.
Anything is possible, if you got the cash to do it
[This message has been edited by nblanchard (edited November 20, 2001).]
Old Nov 20, 2001 | 03:13 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I wanna see the pic!
Old Nov 21, 2001 | 01:07 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i've heard rumors of a company in canada coming out with a turbo kit for a L98 fbody, wish i saved the link to their website...i'll try to find it
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Nov 21, 2001 | 05:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by WS6Formula350:
I have been looking around on the net for a turbo kit for the tpi and i have not found. I know that one is made for the LS1 but like i said i haven't found one for the L98. Can anyone help???</font>
The turbo is actually the easy part.
Getting the fuel and timing is much harder.
All the pieces exist for doing a 89 Turbo Trans Am, using a version of the GN engine.
That way you can take advantage of the years of work in getting that engine to be a real work horse, and you save almost 100 lbs..
The weak point on the SBC when turbo'd is driving over the crank, with a GN engine the fuse is the headgaskets.
Tuning a turbo motor is something not to be taken light.
Old Nov 21, 2001 | 06:04 PM
Guys i was reading on the power adder board and they say rumor has it that incon is in the process of perfecting a twin turbo kit for third gen. They make one for the LS1, so let's see what happenes. The kitt installed is $50000. It under turbo-yes! I believe.
Old Nov 21, 2001 | 06:05 PM
sorry too many zeros $5000
Old Nov 21, 2001 | 07:56 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
If you want to see pics of the Firefox GM twin-turbo concept car, go visit <A HREF="http://www.skulte.com/other.html">http://www.skulte.com/other.html</A>
Old Nov 25, 2001 | 09:11 AM
nblanchard's Avatar
That is what the picture I have looks like... Really nice setup, made 500horse and 500ft/lbs....
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 25, 2001 | 10:18 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can make 500 horses with the right cam and heads.
5,000.00 for any power adder is just too much money. Especially for a turbo.
A buddy of mine runs 10.9 on his camaro. 383
with brodix heads, big cam, 750 holley, etc.
His TOTAL investment is less than 5k.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
