Has anyone JET HOT coated their intake pieces?
Old Nov 23, 2001 | 11:58 AM
Raptor Pilot's Avatar
Anyone? Anyone? Class? Anyone? Just thinking that it might help keep the intake charge down a little as well as look good. Any thoughts? I am considering doing it.
Old Nov 23, 2001 | 12:03 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yep, I had my complete TPI Setup done.Looks polished with out the hassle anymore.
Old Nov 23, 2001 | 12:40 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
how mcuh did that tpi coating run you?
Old Nov 23, 2001 | 11:14 PM
cort351w's Avatar
Another option is to get it all powder coated. I may be doing this. Haven't seen it on tpi, but I have seen a fox pusstang with a red powder coated intake--it looked really good. I think the key here (like when you're changing the paint or the interior colors) would be to make sure it matches. Depending on what you do, it could look really good or really horrible. Pretty obvious, I know.
Old Nov 24, 2001 | 12:45 PM
formul8!!'s Avatar
Car: 2004 GTO
Powder coating the TPI intake pieces looks nice, but it's not a thermal coating.
Old Nov 25, 2001 | 12:22 AM
breathment's Avatar
hey Raptor Pilot you beat me to asking this!!
i have seen a few setups people have using exhaust tubbing, i did an experiment on an Integra that i used to have before my GTA. where i wrapped up the intake with insulation, and since weaker 4 cylinder engine are more effected (noticably) by engine temps, i could always tell the difference when had cooler air coming in (had a temp sensor hooked up in the intake). and after i insulated everything it ran alot cooler and better, then the same day i did it some WOMEN turned in front of me and needless to say im now driving a GTA.
my opinion its well worth getting it coated.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 26, 2001 | 11:55 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
<font face="Verdana, Arial" size="2">Originally posted by BigMike92Z:
</font>
$150. Contact
THERMO SHIELD
12208 N. Nebraska Ave.
TAMPA,Fl. 33612
(813)631-0906
I had my rods/pistons coated with some coating to reduse heat. and My TPI and headers ceramic coated
92 25th Anniv. Z28
383 Stroker/Lunati Pro Mod Lowerend
AFR 210cc Heads,Solid Roller Cam,
ArtCarr 700r4,Strange 12bolt
[This message has been edited by TPl383 (edited November 26, 2001).]
Old Nov 26, 2001 | 12:23 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Isn't ceramic coating on the headers supposed to keep the heat in the headers to improve thermal properties of the exaust flow?
Old Nov 26, 2001 | 12:39 PM
cort351w's Avatar
Well, an insulator is an insulator. If you put pipe wrap on a hot pipe in a cold environment, then you will help keep the pipe's contents hot. Similarly, if you put insulation on a cold pipe in a hot environment, you help keep the pipe's contents cold.
However, I don't much about JET-HOT other than it's supposed to keep the heat in the headers (i.e. insulate the header pipes). I would assume that it acts like other insulators in this regard.
[This message has been edited by cort351w (edited November 26, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
Street Lethal
Aug 12, 2015 11:33 AM
