Crappy L98 Oil Pressure
Subscribe
Nov 30, 2001 | 06:14 PM
I have an 89 GTA, L98 motor. Oil pressure is always between 15 and 30. What can i do to get it higher?
1980 Camaro, '88 Police 350 engine, Headers, full exhaust, completely redone, my baby!
1988 Iroc-Z L98, MSD 6a, Accel coil, K+N's, Airfoil, Coolant Bypass, Flowmaster, Gears, Late model Bose, I like the 80 better
Reply 0
Nov 30, 2001 | 08:41 PM
What weight oil are you running, what type, and how long between oil changes?
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Reply 0
Nov 30, 2001 | 10:22 PM
Quaker state 10w30, ive only had the car for 4000 miles, but it was changed the day i got it, and 3000 miles after that
Reply 0
Dec 1, 2001 | 12:39 AM
best to manually check the oil pressure to
assure the 'real' pressure. possible sending unit
or gauge is incorrect. assuming the pressure is
low and forming a repair without testing is
quite expensive.
oil pressure is related to the clearences in
the engine. the looser the clearences the
lower the pressure.
most gauges are for reference and not gospel.
at idle 12-15psi is plenty. the rule of thumb:
10 pounds of pressure per thousand rpms
over pressure is drag through the pump.
airdeano
Reply 0
Dec 1, 2001 | 02:29 PM
Yo,you may like the 80 better but whats going to be worth more in on coming years?
The Irocz
Reply 0
Dec 2, 2001 | 12:47 AM
Worth more to me? The 80 will. So that's all that really matters to me.
Reply 0
Dec 2, 2001 | 12:04 PM
The oil pressure sender fails on these cars, due to its location above the oil filter on the 89 and newer. If its ok, and the gauge is working properly then you've got a problem with the oil pump, or the engine itself.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Dec 2, 2001 | 12:16 PM
I thought the correct oil weight for an L98 was 5w-30...that what it says on my valve covers
Reply 0
Dec 2, 2001 | 08:41 PM
They do say to use 5w-30 but that is a thin oil most people I think run 10w-30 and some thange thair oil from 5w-30 winter to 10w 30 or 10w-40 in the summer. As for your oil presure problem you do need to manualy check it if it is low then their is usaly two things that couse it oil pump or barrings both jobs a pian to do in are cars unless you have acsess to a lift and a trans jack.
87gta 355 fastburn heads,slp headers,flowmaster exhaust, LT4 hot cam and a lot more
Reply 0
Subscribe
