350 TPI
Old Jul 1, 2008 | 04:20 PM
817bigtex's Avatar
Car: 1993 Mustang,1989 GTA
Engine: 5.0 302,5.7 350
Transmission: AOD Built 500HP Mustang
Axle/Gears: 8.8 Rear Built 4.10's Mustang
350 TPI
So I sold my other Camaro and got a 1989 350TPI GTA Trans Am. I did the Tune up.
Here is what I'm going to buy
http://www.hawksthirdgenparts.com/in...OD&ProdID=1081
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...t=HOK-16767HKR
http://www.hawksthirdgenparts.com/in...OD&ProdID=1252
http://www.hawksthirdgenparts.com/in...OD&ProdID=1112
http://www.hawksthirdgenparts.com/in...OD&ProdID=1114
http://www.hawksthirdgenparts.com/in...OD&ProdID=1444
http://www.hawksthirdgenparts.com/in...ROD&ProdID=978
http://www.hawksthirdgenparts.com/in...ROD&ProdID=970
http://www.hawksthirdgenparts.com/in...ROD&ProdID=965
http://www.hawksthirdgenparts.com/in...ROD&ProdID=966
http://www.hawksthirdgenparts.com/in...OD&ProdID=1803
THis is what im going to buy for my 89 GTA Trans AM.
Old Jul 1, 2008 | 10:19 PM
817bigtex's Avatar
Re: 350 TPI
ANybody?
Old Jul 1, 2008 | 10:59 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Re: 350 TPI
hey would those headers work with all that emissions crap and about the ignition box would u just need that wiring harness to wire it up cause id really like to get the msd ignition box and some headers
Old Jul 2, 2008 | 09:38 AM
87350IROC's Avatar
Car: 87' IROC
Re: 350 TPI
Originally Posted by 817bigtex
ANybody?
Whats your question?
Those injectors are WAY to big for the modifications you described. I'd stick with the stock ones until you get heads/cam.
Old Jul 2, 2008 | 12:02 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: 350 TPI
And even with heads/cam the Ford 24lb/hr will be plenty. I also think that you should get a y-pipe fabbed up for your car instead of buying that one. Unless you get the hooker 2055s that come with a y-pipe that is very good.
Old Jul 2, 2008 | 01:31 PM
817bigtex's Avatar
Re: 350 TPI
My question was is that a good Combo. I was also going to get this http://www.hawksthirdgenparts.com/in...OD&ProdID=1328
Old Jul 3, 2008 | 08:18 PM
817bigtex's Avatar
Re: 350 TPI
New part list
http://www.hawksthirdgenparts.com/in...ROD&ProdID=120
http://www.hawksthirdgenparts.com/in...OD&ProdID=1977
http://www.hawksthirdgenparts.com/in...OD&ProdID=1252 3.73
http://www.hawksthirdgenparts.com/in...ROD&ProdID=855
http://www.hawksthirdgenparts.com/in...ROD&ProdID=832
http://www.hawksthirdgenparts.com/in...OD&ProdID=1232
WHat about this list. I just want 350+RWHP
Old Jul 3, 2008 | 10:33 PM
87transGTA's Avatar
Car: 87 GTA
Re: 350 TPI
hey i got a Q about those headers would they work with all that emmision connections on the stock headers? oh and i have those springs very good i like them alot
Old Jul 4, 2008 | 12:40 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: 350 TPI
The 42#/hr injectors are probably correct for a supercharger. How are you going to tune this thing. What computer are you going to use?
Old Jul 4, 2008 | 08:37 AM
817bigtex's Avatar
Re: 350 TPI
Get a Dyno Tune and use the Computer that came with the Car. Is that a good list of parts?
Old Jul 4, 2008 | 05:19 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: 350 TPI
You need to read throught the notes on that catback.......
"Notes: 2.500 inch inlet 3.000 inch outlet intermediate pipe."
You don't want the 2.5 inlet.
I did'nt read through the hawks links. If your gonna run a charger, make sure you install a quality high pressure fuel pump and build a good shortblock with a forged rotating assembly.
Old Jul 4, 2008 | 06:37 PM
817bigtex's Avatar
Re: 350 TPI
http://www.hawksthirdgenparts.com/in...OD&ProdID=1140
http://www.hawksthirdgenparts.com/in...OD&ProdID=1490
http://www.hawksthirdgenparts.com/in...OD&ProdID=1619
How much HP will this give me to the Wheels with a Dyno Tune?
Old Jul 5, 2008 | 12:00 PM
817bigtex's Avatar
Re: 350 TPI
Im going to run a 100 shot of Nitrous. Also need help on a wich Cam to get or just leave the stock cam? Going to port and polish the Cylinder heads. Leave the car at 320+RWHP. Its only going to be driven about 2 or 3 days a week, for probably only 40 miles.
Old Jul 8, 2008 | 11:46 PM
817bigtex's Avatar
Re: 350 TPI
Anybody? Im a member at a Mustang forum and get way more replies there then here
Old Jul 9, 2008 | 12:51 PM
drewnashty's Avatar
Re: 350 TPI
haha
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
