What is telling my ECM to run engine RICH!!!!
Old Jul 8, 2008 | 04:27 PM
pa_richardson's Avatar
Camaro 5.7 1990 SD TPI........
My engine is runninng very rich itis pumping on alot of smoke..I have played with the timing it does not seem to make any difference to the smoke problem....I have replaced most sensors, ecm, injectors,coils,etc but no joy..
What tells the engine to pump somuch fuel? The FP is correct and a good spark...
There is something i am not seeing here, any ideas would be so helpful..
Old Jul 8, 2008 | 05:01 PM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
Re: What is telling my ECM to run engine RICH!!!!
o2 sensor?
Old Jul 8, 2008 | 05:25 PM
jms's Avatar
jms
Is the computer throwing any trouble codes?
jms
Old Jul 8, 2008 | 08:15 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I would be looking for one or more leaking injectors. It's doubtful the ECM is setting it that rich.
Old Jul 9, 2008 | 12:55 AM
87350IROC's Avatar
Car: 87' IROC
pa_richardson,
I feel your pain. I'm currently diagnosing a similar condition. Except my fuel pressure is very low from what I think is a bad fuel pump, and the motor is still running very rich. My injectors are not leaking. My scan tool says all of the sensors are reading correctly. I will let you know if I find my problem.
Does your fuel rail hold pressure after the motor is stopped?
Old Jul 9, 2008 | 02:40 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Vacuum leak, checked your MAP reading?
Exhaust leak?
O2 sensor? new? wireing ok?
Old Jul 9, 2008 | 05:05 PM
Hi thanksfor your help i reset my base timingto 6 degrees and changed MAT sensor as this was one i had not done i had already changed o2, injectors, IAC, dizzy,coils, plugs, CTS, map and leads...I also put back on my old Knock sendor after this is starts fine and does not smoke at all..
But sadly when it goes changes loop it then starts to stumble and has mild backfiring and does notrev very well..
So this is now my new problem any ideas please...
Im thinking maybe O2 is clogged up or needs replacing after its long rich running problem???
Or does the base timing need to be set when its warm not cold?
Or maybe my engine is cursed???
Paul
Old Jul 9, 2008 | 05:41 PM
jms's Avatar
jms
jms
That should be the first thing you look at. Your computer can/will tell you what is going on.
jms
Old Jul 9, 2008 | 05:57 PM
Hi Yes sorry it was a 15,43...
I cant understand why the CTS is showing faulty asi have changed it and the mat...and the knocksensori put down tothe popping and backfiringwith it running lumpy...
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
