coolant system bleed-off
Old Aug 13, 2008 | 03:48 PM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
I'm looking for where the coolant system bleed-off valve might be.... have had so much trouble with overheating lately, maybe thats where im going wrong and i may have an air pocket i need to get rid of. since i just replaced the thermostat, but the car overheated again, do i have to replace the thermostat again? is it likely that it messed up after overheating just once on this particular thermostat?
Old Aug 14, 2008 | 04:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: coolant system bleed-off
There is no burp plug on these cars.
Are your fans working?
Are you missing your air dam?
Old Aug 14, 2008 | 09:27 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
i heard that turning the heater on will help release some pockets.... and whether i got the air dam depends on where that is lol. i put some coolant into the coolant tub of course, then the radiator until it filled up and then unplugged the big hose from the top of the radiator and poured as much as i could in there and quickly put it back on before i spilled all of it out lol. i didnt try the heater thing, so i guess i will try that this time, but should i replace the thermostat again u think?
Old Aug 14, 2008 | 09:33 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I had a problem with overheating after putting head gaskets on a blazer. I ahd to pull the thermostat back out and fill the block by pouring it into the thermostat hole. Ran cool after. When does it overheat?
Old Aug 15, 2008 | 09:30 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
maybe its because im not pouring it into the hole where the thermostat goes into the block....hmm lol. i'll try that this time. i have been pouring it into the tube so that the coolant is on top, but havent been putting it underneath.
Old Aug 15, 2008 | 11:52 AM
wolfspirit187's Avatar
Car: 1988 trans am GTA
Engine: 350 V8 tpi roller motor
Transmission: 700-R4
Axle/Gears: 3.73 b/w posi will change out soon
you can also try lifting the front enad of the car so the radiator is higher up then the heater and runnign the car air will travel to the highest point so if you make the radiator the highest point it will go there then you vcan burp it out from there
Old Aug 15, 2008 | 11:57 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
ok, i'll give that a try too
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need to do any of that, the radiator cap is already the highest point in the system.
Old Aug 16, 2008 | 06:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Agreed. I've never done anything to fill up my cooling system other than filling it at the radiator.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 20, 2015 06:59 PM
FormulasOnly
Sep 10, 2015 09:07 PM
TheExaminer
Sep 7, 2015 08:34 AM
