LS1 injectors on tpi?
Old Jan 25, 2009 | 02:06 PM
marktg1983's Avatar
Car: 1990 IROC-Z
Engine: TPI 350 L98
Axle/Gears: stock
I am in the process of building my tpi up, and I am down to the end. I have a bbk 58mm tb and afpr and the ram ported to match the tb, slp runners and a port matched base and siamesed openings on the ram also. All I need are injectors... I have been looking around for a good set, and the other day I talked to a friend that had some stock LS1 injectors. He says they will fit and work well on my car.
Does anyone know if they will actually fit and use the same wiring? Will I need to modify anything to make them work?
Old Jan 25, 2009 | 07:24 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: LS1 injectors on tpi?
they will fit, but they are 23lb in you car. the ls1 runs rail pressure of 58 where we run 43.5.
Old Jan 25, 2009 | 08:08 PM
marktg1983's Avatar
Car: 1990 IROC-Z
Engine: TPI 350 L98
Axle/Gears: stock
I read that the LS1 injectors are 28#, and I have an adjustable fuel pressure regulator that I believe will go high enough for them.
Old Jan 25, 2009 | 08:12 PM
moez28's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 86 IROC Posi, ?????
He is right if they are 98, 01, or 02 injectors because they were 28 lb injectors at 58 psi. If they are 99 or 2000 model injectors, they are only 26 lb, and would be less than your factory injectors on your fuel pressure. Get a set of SVO 30's, and never worry about it again.
Old Jan 26, 2009 | 10:48 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The LS1 injectors are a different height. Some third genners have had fuel leaks. Do a search on this matter. I have posted several times about the height differences. I believe that due to fuel leaks, SLP has stopped selling LS1 injectors as replacements in 3rd gen EFI cars.
SVO does not exist anymore. I recommend that you install Ford Racing 24#/hr injectors. I have been running mine for 12 years now.
Old Jan 26, 2009 | 12:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, my dad's engine is having that problem right now. The LS1 injectors are slightly shorter, and they do not have the injector holding clips that keep them securely in the fuel rails. So they leak a lot.
Old Jan 26, 2009 | 04:16 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
http://fuelinjectorconnection.com/sh...&productId=134
or
https://www.thirdgen.org/forums/engi...tml?highlight=
Chuck
Old Jan 26, 2009 | 04:35 PM
moez28's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
SVO is the same as Ford Racing...you knew what I meant...
Old Jan 26, 2009 | 06:56 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
moez28, my comment was not an insult, dont take it that way. You and I know that SVO has become Ford Racing,,, but others may not know that. That is why, I correct the use of SVO if I post in the thread.
Old Jan 27, 2009 | 06:34 PM
moez28's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I wasnt taking it as an insult...
Old Jan 27, 2009 | 07:15 PM
southbay08's Avatar
There is a very simple solution to this problem. Some of the newer design/style injectors are approx 1/4" shorter than the stock injectors. (TPI). All you need to do is apply a second oring and you will never have a problem with leakage again. That second oring will give the additional length that you are missing. As for the clips, not necessary, the pressure from the fuel rail holds them in place. We would be more than happy to help you. We have a huge inventory of injectors, I am sure that we can help you find what you need and we will also provide you with the additional orings and installation instructions.
www.southbayfuelinjectors.com
516-492-6504
Old Jan 27, 2009 | 11:47 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
heres food for thought....
i talked to a friend who is in tool and die and he said why not mill the parts where the fuel rail down for the shorter injectors? Thwn, if you wanted to run the stock height injector put a spacer in between the fuel rail and intake
Old Jan 28, 2009 | 04:35 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
i talked to a friend who is in tool and die and he said why not mill the parts where the fuel rail down for the shorter injectors? Thwn, if yo use u wanted to run the stock height injector put a spacer in between the fuel rail and intake
you can do that but, the injector is 1/4 inch to short. if you mill the stands do not take off more than 1/8 inch. if you take too much the fuel rail will hit the runner tubes. the 1/8 will work
Old Jan 28, 2009 | 06:46 AM
southbay08's Avatar
why mill if all it takes is an additional oring? seems to be alot easier to me
Steve78LT
Feb 24, 2016 12:15 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
