wont idle
Old Mar 1, 2009 | 01:17 PM
jeffj30's Avatar
wont idle
i have 87 camaro 350 tpi and it wont idle without my foot on the gas any ideas it does need a mass air flow sensor but it was idling then i had it running the other day and just quit ideling it will start fine as long as my foot is into it, any ideas would be great thanks.
Old Mar 1, 2009 | 01:26 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Re: wont idle
I had the same problem on a 89 iroc a few years ago. It was the MAF. It didn't throw a code but took it to the dealer and they dianosed it to the sensor. Replaced it and all fine
Old Mar 1, 2009 | 02:07 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Re: wont idle
I just had this same problem yesterday. see my recent post - ":Starts then dies"
The MAF gods must be angry
Try unplugging it and it will probably run, but not so great throttle response - *way* better than with it plugged in.
I did the test twice to make sure. Just ordered a new one - ouch.
Old Mar 1, 2009 | 02:58 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: wont idle
Check the TPS and IAC while you're at it.
Old Mar 1, 2009 | 02:59 PM
jeffj30's Avatar
Re: wont idle
sorry im new to fuel injection what is IAC
Old Mar 1, 2009 | 05:08 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: wont idle
idle air control valve.its under the tech section along with the throttle position sensor and how to check them.
disconnect the maf and see if it runs any better, if it doesnt than thats not it.
also check for vacuum leaks around the plenum, cracked hoses, loose hoses. anything like that, also spray some carb cleaner down the throttle body and see if it helps at all, sometimes if the idle air control valve is gummed up itll help out alittle.
are you throwing any code? does the car stay on if you hit the throttle? if not check the tps, and if it does help test your egr to see if its stuck open
Old Mar 1, 2009 | 07:56 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Re: wont idle
I had a problem with my car not wanting to idle, changed everything imaginable accept the idle air control valve, turned out to be a bad distributor. But a reman in there and that baby idled awesome. But the tps getting replaced also helped, because mine was bad. The 2 owners did absolutely no part changing, they left it all stock so im the one taking a big damper in my wallet right now getting brand new things on the car. But if not the distributor try checking your magnetic pick up, if that goes bad, that will cause the idle problem. But try picking up a new maf, its not much, tps as well to begin things off.
Old Mar 1, 2009 | 09:07 PM
jeffj30's Avatar
Re: wont idle
I fixed my problem it was the wire plub wasnt all the way in on the iac thanks everyone, i feel dumb now.
Old Mar 2, 2009 | 02:35 AM
watajob's Avatar
Car: 92 T/A 'vert
Re: wont idle
Why? You fixed the problem!
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
