350 throttle body
Old Apr 8, 2009 | 11:35 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
350 throttle body
I have a question i seen this guy that is selling a BBk tb its a 52 mm and i have a 89 tpi i am rebuilding and i was thinking of putting that tb for $200 is that a good deal also would i have to get certain kind of gasket or can i use the one i have for my stock one
Old Apr 9, 2009 | 10:24 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
re: 350 throttle body
You can use a 52mm TB but you have to be careful of the linkage, I believe 82-88 had a different linkage than the 89-92's. I think you can use the stock gasket, if not, they are pretty cheap to buy.
Old Apr 10, 2009 | 07:05 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: 350 throttle body
He's right, the linkage mounts are different. Make sure it's the right year, as the BBKs cannot be converted. I'd get the part number from the guy and then check it at Summit Racing. The price is decent. New they are around $310. I like the BBKs because they use bearings for the throttle shafts, which will last a lot longer than a bushed or unbushed shaft (these will eventually cause a vaccum leak as the shaft wears into the bushing or the casting).
As for the gasket a stock one will work, but you should check it on the throttle body to make sure it does not intrude into the throttle bores. Then I would check it against your plenum to make sure the holes in the plenum are the same size as the gasket or larger. If not I'd port match the plenum to the gasket so there is not a flow disruption.
Old Apr 10, 2009 | 02:14 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
i will check that although i forgot to tell you guys its from a 95 Z28 he told me the part number its BBK E.O. D-245-9 were can i research for it and would it be a good upgrade from my stock one
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
