Pulling distributor
Old Jul 4, 2009 | 11:33 PM
SupplySgt's Avatar
Car: 87 IROC-Z (work in progress)
Transmission: 5 speed manual (T56 in future)
Axle/Gears: 3.08 (3.73 or 4.10 in the future)
Pulling distributor
Trying to pull the dizzy off of my 87 IROC and it does not want to come out. is there something else holding it in that I'm not seeing? and if so how in the heck do I get to it? I'm thinking I may need to pull the intake off to get a good look but i'd hate to do that if I don't have to. Thanks in advance.
Old Jul 5, 2009 | 12:16 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Pulling distributor
The only thing holding it in becides wires and eletrical connections should be the distributor hold down clamp. If thats out it should slide out realitivly easily?
Old Jul 5, 2009 | 06:26 PM
SupplySgt's Avatar
The only other thing I can see relatively close to the distributor is a bolt that I can't seem to get to. under the dizzy. Don't know how I can get to it w/o taking the intake off. Nowhere to get a socket wrench into and there's not enough room sideways to get a regular wrench
Old Jul 5, 2009 | 06:52 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
You need one of these:
http://www.summitracing.com/parts/WMR-W1189C/
Old Jul 5, 2009 | 07:02 PM
Yup thats the hol down clamps bolt. The way i usually do it is with a flex fittings for my ratchet. Its still not pleasent but i can get it out with alittle effort. Dont forget to mark your distributior befor you pull it just as a side note if you didnt know already. It will make the assembly much easier.
Old Jul 5, 2009 | 07:54 PM
SupplySgt's Avatar
Thanks. This the the first time I've had to pull the dizzy on a 3rd gen. and the dizzy is being replaced so i'll be setting timing and everything when i put the new one in. it's sooo much easier on my 79. way more room to work with.
Old Jul 5, 2009 | 08:00 PM
Well than one thing you might want to do is set the motor to TDC #1 while the distributor is still in place as im sure you know TDC on the harmonic balance if for cylinders 6 and 1 depending on which revolution its on. Its not hard to find if you dont set the motor up now but youll have to pull a spark plug and turn the motor over by hand while feeling for compression bla bla bla when right now you can just pull the cap and see where the rotor is pointed with the harmonic balancer is at TDC 1 or 6. Just a little time saver.
Old Jul 6, 2009 | 10:34 AM
SupplySgt's Avatar
Ok whoever designed the way it is near the dizzy is an idiot. Doesn't help that the wrench is a POS
777Shock777
Oct 29, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 31, 2015 07:00 AM
stalkier
Aug 21, 2015 01:54 AM
86IROC112
Aug 17, 2015 07:57 PM
