Where's the best place to get a TPI Injector and what brand?
Old Aug 21, 2009 | 04:19 PM
FlameFeather's Avatar
I might need a single TPI injector to get my Trans Am running right again and I'm pretty much flat broke so I was wondering if you guys knew where I could get a decent and reliable TPI fuel injector for less then the $80 some that Advance Autoparts is asking for? Also what is a good brand to stick with the remaining stock GM (AC Delcos?) fuel injectors?
Would you have any reccomendations?
Old Aug 21, 2009 | 08:13 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Where's the best place to get a TPI Injector and what brand?
Do a search for Fuel Injection Conection. I'm quite sure they can fix you up for a very reasonable price.
Old Aug 22, 2009 | 01:03 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Do yourself a favor and yes,go to www.fuelinjectorconnection.com
call Jon at FIC,there is no mistake here,its the best of the best !
Old Aug 23, 2009 | 06:36 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
what makes you think just one is bad? or did you loose one? I have a complete set of 24lb ones out of a lt1. PM me if your interested. $50shipped.
Old Aug 23, 2009 | 10:21 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
http://www.summitracing.com/parts/VNM-HP-619-8/ this is what i run. youre 305 too, should work but a whole swap would be needed. theyre rated 10% more flow for extra horsepower. but replacing one would off set the whole shabang. post your description on the tech-forum, this guy(SpitotRs305) he'll help you, tell him i refered you.
Old Aug 24, 2009 | 05:31 PM
southbay08's Avatar
If you are still searching for injectors we carry both 19lb and 22lb bosch design lll fuel injectors. you can call us at 516-492-6504, PM, or email at info@southbayfuelinjectors.com
Old Aug 24, 2009 | 09:37 PM
firebird310's Avatar
Car: 89 FORMULA 350
Axle/Gears: 327
I RECENTLY BOUGHT A SET OF ACCEL BRAND FUEL INJECTORS 21# FROM JEGS. THEY WERE $278.00 DELIVERED. THE TECH I TALKED TO AT JEGS LOOKED IT UP AND SAID THESE WERE CORRECT FOR A 350 TPI (89). THEY WORK GRAET, VERY HAPPY.
Old Aug 26, 2009 | 02:02 AM
if you need an injector, i can send you a used one for just s/h. theyre just sitting. id send it and when you receive it, just send s/h back.
Old Aug 31, 2009 | 01:01 PM
I have one that may have went bad. (Still trying to diabnose the problem.) I have a 305 though. Wouldn't 24lb be too much? They're for the 350 correct?
For real? That's a very generous offer. How many lbs and how old/used/what's it out of?
Thanks for all the great suggestions and offers! I still have to figure out what my problem actually is. It might not be a fuel injector at all. I don't know for sure. I'm going out to do a OHM test and check all the lines right now.
Old Aug 31, 2009 | 01:09 PM
Calderone's Avatar
Car: 87 Vette
let us know !
Old Aug 31, 2009 | 05:49 PM
Originally Posted by Calderone
let us know !
I just tested the OHMs in each fuel injector but I'm not sure what the results mean. I've heard they should all be within .5 of each other and none of them were. I first tested cold, then warmed it up to operating temperature and tested it warm with the engine off. Here is what I got...
Chart explanation: OHMs reading - (Passenger side)Cylinder__Cylinder (Drivers side) - OHMs reading
16.6 - 8________7 - 11.6
3.9 - 6________5 - 16.1
16.1 - 4________3 - 14.7
10.7 - 2________1 - 15.3
Note: Cylinder 6 fluctated from 3.9 to 4.0, and Cylinder 3 fluctuated from 14.8 to 14.8.
Hot...
11.0 - 8________7 - 11.5
1.8 - 6________5 - 16.7
11.5 - 4________3 - 12.0
8.3 - 2________1 - 13.3
The readings were alot lower when it warmed up, and they were all over the place. None of them were within .5 like I heard someone say in a youtube tutorial.
What does all this mean?
Old Aug 31, 2009 | 05:57 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Hot...
it means its injector time... call jon at FIC get the bosch 3 770 888 1662
Old Sep 1, 2009 | 12:05 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
irocuroc is right, you need a full set of injectors.
you have one that is checking ok, #5. the rest are junk.
with a good set of injectors, the ECM sees around 6~7 amps of current.
with the hot resistance you gave, the ECM is seeing around 16 amps of current. sooner or later that will kill the ECM.
i just recently had a 91 vette that ran so bad, it had to be towed to the
shop. the injectors in it were not as bad as yours are.
i put a set of Bosch 3s in it and it fired up and ran great, the owner said its been years since it idled that smooth.
i don't know if they make the Bosch 3s in 19 pound or not.
you can contact either southbay or FIC to find out.
Old Sep 1, 2009 | 07:05 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
the bosch 3 come in 19 and 22, the 19's are white
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
