Lt1 using TPI harness?
Old Aug 25, 2009 | 01:10 PM
rx8ss's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 bolt
I have a 87 Iroc-z with a 5.0/ now 5.7 and a T5. I wanting to know if it would be possible to use the stock harness on a LT1. I would modify the intake to accept the distributor and delete the optispark. I know that the 92/93 LT1's used speed density batch fire. From what I can tell the early lt1's use pretty much the same sensors and locations. Tuning is my main hold up. I really do not want to rewire under the hood if possible.
Thanks for any comments.
Old Aug 25, 2009 | 01:29 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Lt1 using TPI harness?
Yes if you remove the opti and drill for a distributor you can.
I did the same thing with my 383 lt1.
Get yourself a lt1 throttle cable. If ya have any other questions post em up or just ask.
Do you already have a LT1? What year? etc...
Old Aug 25, 2009 | 02:01 PM
rx8ss's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 bolt
Yes, 383 splayed caps, squared decked, forged srp pistons coated top and all, I beam rods, forged crank, ported polished enlarged valves, 292 sfi cam, and more. Was building for another car but life changes caused other things to happen, but kept engine.
Set it up for anything I wanted to throw at it. I am liking to turbo idea, but with a tpi harness maybe not.
I do have a Autorotor supercharger off of a vortec engine.
Old Aug 26, 2009 | 05:45 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
this may sound dumb,but the motor is setup yoo where you can put a distributor in a lt1? i know the intake needs drilled. I am debating on a lt1 or ls1 swap and i like the prices alot better for the lt1 swap better.
Old Aug 26, 2009 | 06:49 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Why not turbo it with the TPI harness. You can run a STOCK 7730 ecm with the $59 code.
http://www.code59.org/index.php?opti...d=6682&catid=9
alot of people running Turbo efi setups here. Go check out the POWER ADDER FORUM.
Just drill the intake for a distributor , get it tuned n/a running on code 59 and add boost.
thats what Im in the middle of now.
383 LT1
callies crank, callies rods, je pistons, etc.. Novi 2000 sc pullied for 12 psi right now.
Old Oct 7, 2009 | 10:09 AM
c10crewchief's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 355cid
Transmission: TH350
Axle/Gears: 3.73 Open Rear
So what Part Number of the ECM I would be looking for to perform a 383 LT1 swap as shown above? My dad has been told to look for a 89-92 TPI ECM preferable from a Firebird. Is this true? I have found some on eBay but want to make sure it is the correct P/N. Thanks
Old Oct 7, 2009 | 06:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
So long as the engine has fuel and spark it will be happy It doesn't know what is controlling it.
You could even run the TPI MAF setup for easier tuning
Old Oct 7, 2009 | 06:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Depends whether you want to run the MAF system or the MAP (speed density )
Two different computers and wiring.
MAF , easier to tune has 1227165 ECM (86 - 89 ) but requires the MAF sensor on intake before TB
MAP uses 1227730 ECM (90 - 92 F-Body ) which allows you to run a air filter direct on the TB
1227727 is the Vette ( 90 - 91 MAP ) weatherproof underhood mounted ECM; uses different harness and ECM plugs
You will also find the same ECM's with different part #'s given by the factory when they went across the parts counter as reman units.
Need to cross reference to confirm
Old Oct 8, 2009 | 07:27 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I don't know if this helps, but my '93 Trans-Am still uses a PROM style computer...they didn;t go to flash style ECMs until '94+. The computer just sits in the engine bay on the pass. side on the firewall area behind the wheel well. This may be useful since your TPI harness and ECM will be PROM based and located inside the pass. compartment. Just throwing that out there in case it helps with some of this...locations and such.
Old Oct 8, 2009 | 06:28 PM
Engine: 355cid
Transmission: TH350
Good, then I found the correct ECM. But if it says the memcal has been removed, then does that mean it doesn't come with a chip? Thanks for the info!
Old Oct 8, 2009 | 06:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
correct. your going to need a chip/memcal if a Pre 93 ecm/pcm
Old Oct 11, 2009 | 03:20 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
So can i use my stock 87 305 tpi wiring harness and computer with any lt1 or specific year? Just with the distributer modification.
Old Oct 11, 2009 | 03:37 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yes you can.
u need to use the lt1 accessories.
You need to mod the timing cover to get rid of the opti.
You need to drill your intake for a distributor.
Old Oct 11, 2009 | 03:59 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Any lt1 or just 92-93? Details on modding the cover? also what did you do for the PS high pressure line?
Old Oct 11, 2009 | 04:20 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
ANY engine will run of your harness.
I used AN fittingand braded lines for my PS pump.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
stalkier
Dec 6, 2015 11:25 PM
IBrockZ
Aug 20, 2015 12:20 PM
Sanjay
Aug 12, 2015 03:41 PM
