Need help with TPI cold air intakes!!!
Old Oct 14, 2009 | 06:05 PM
Hollow_kmh's Avatar
Car: 1989 Camaro RS
Engine: V-8
Transmission: 5 speed
I have a 87 IROC Z TPI. Can you use a Cold Air intake on a TPI? Please respond back. Also, what is the best way to install a Cold Air intake on a TPI? Thank you
Old Oct 14, 2009 | 06:11 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: Need help with TPI cold air intakes!!!
Originally Posted by Hollow_kmh
I have a 87 IROC Z TPI. Can you use a Cold Air intake on a TPI? Please respond back. Thank you
i bought a $250 slp cold air kit. but i have an 86 and i had to relocate my battery to my driver side, and thats where the charcoal canister was, so i tossed it. (i already had the air pump removed and all other emission bs)
Old Oct 14, 2009 | 07:34 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
i would suggest hollowing out the stock intake. there should be a few threads on it
Old Oct 16, 2009 | 03:08 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Or you could do what I did, take down measurements from your TB to the air filter and make your own CIA...
I made mine for around 20$ in the lowe's plumbing section..
Old Oct 17, 2009 | 05:09 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Sure you can.......heres what I built for my L98 in my '89 XJS jag
Old Oct 17, 2009 | 05:29 PM
DANNY25SS's Avatar
Car: 92' Formula T-Top
Engine: L98 With Custom CAI
Transmission: BUILT 700R4 with B&M Mods
can anyone post pics of the cold air setup they did as im gonna try to go it this weekend. i have a 92 formula l98 and am wondering what others did its hard to find pics of it...
thanks
Old Oct 18, 2009 | 08:36 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
dont buy the k &n that goes next to your smog pump.
i did and the way its set up doesnt help it any.
Old Oct 18, 2009 | 09:20 PM
Damon's Avatar
In a Camaro, doing the usual mods to the stock airboxes and installing K&N filters seems to get you about everything that's reasonably getable (and the setup is already "cold air"). Firebirds have a more difficult time since they don't have the hood clearance for the intake plumbing to go over top of the radiator- they have to go to the side and have less direct access to "cold air".
Old Oct 19, 2009 | 09:41 AM
Hollow_kmh's Avatar
Car: 1989 Camaro RS
Engine: V-8
what is the best way then?
Old Oct 19, 2009 | 01:40 PM
Abubaca's Avatar
As stated, the TPI in a Camaro already is a "CAI" since it's not breathing in hot engine bay air. If you remove the air filters, you can see some baffles below where the filters were. You can cut these out with a dremel or cut off wheel.
This is enough for most of the TPI Camaro's out there. Unless you have a highly modified engine, there's not much more you need to do.
Pontiacs have a MUCH more restrictive intake from the factory, due to the lower hood line, and can really take advantage of a custom or aftermarket cold air set up.
Old Aug 20, 2024 | 07:37 AM
TripleTTony's Avatar
Car: 1987 Camaro IROC
Transmission: 700 R4
Axle/Gears: 9 Bolt Borg Warner 3.27
That set up looks great. do you have links to the parts you added?
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
