TPI Vacuum Line Orientation?
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
Does it go above the fuel rail or below it? It's a little deceptive to me as I'm finalizing the fuel rail assembly.
One booted end near the center of this pic belongs to a plenum port I believe?
The other end nearest the #1 injector cracked off and I'm wondering where that actually goes...
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: TPI Vacuum Line Orientation?
Need help? Check out this thread I started a while back. It has everything you need including a Vac. Line Diagram. Peace.
https://www.thirdgen.org/forums/tpi/...rs-i-need.html
Car: '92 Z28
Engine: 350 TPI L98
Awesome! This may help me out actually. It's dark out and the Trick Or Treaters are preventing me from finishing this vacuum line job...
I will most likely attack this vacuum routing very soon and will give ya a shout & post more pics if I run into problems. I know there are 2 broken lines I must fix in order to save myself a headache after firing this 305 up!
Btw... I figured out the single booted end in my pic belongs to the EGR valve. Thanks to your thread and very much appreciated!
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
question for you guys, where the pcv valve hose connects to the intake manifold on drivers side, im not getting any vacuum there, it actually pushes air out from that port. does urs do the same or no? any ideas why mine does this?
Good question. Does anybody have an answer? Sorry buddy, I would pull my pcv valve hose off to test mine but my IROC isnt running yet.
Car: 1987 Chevy Iroc-Z Z28 Camaro
Engine: 357CI L98
Axle/Gears: 2-77 =[
Hey i know this post is a lil old but yes. its Positive crank case vent. its supposed to push the air out or it would build up pressure.
Car: THE 1989 IROC-Z camaro
Engine: L98 5.7 litter v8
Axle/Gears: Im not sure lol havent had her long
I was haveing the same trouble with mine but I found this diagram online and here is a link to the page http://theking.joakimweb.se/z28/tech.htm this page has a few things that might point us in the right direction
hi guys am kind a new
in this website so I would make this as simple as i can, i need to know where this vacuum lines go to,is for an iroc z 86 305 TPI is the one that is close where de EGR is locate I know one is for the EGR but the other one where it goes?it come from the TPI and the same one comes from the canister but where it goes any help thank you so much
(i use the picture form someone else I don;t know how to upload the iroc 861pictures)
Hi I have a 88 GTA A friend took everything off my motor. So he forgot how to put it back and has now died. I have no clue how to put it back together. I had on mechanic look at it and said there is no direction on where things go and he doesnt want to attempt it. I am screwed. I need some sore of diagrams that will show where thing go and connect to what. Is there anyone that can send me pictures of where wires go vaccume lines and hoses etc. I would be greatfully appreciate this. I would like to get it running. This car has never seen winter of course but it hasnt seen summer for the past 5 years.
Mike Panteluk
Mike Panteluk
Mike Panteluk
Mike Panteluk
Attachment 423955
Attachment 423955
Please and Thank you
Mike Panteluk
