post your tpi powerplant combos
Old Nov 10, 2009 | 09:12 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i really didnt see a thread like this and this should be a sticky of what tpi's can do....i love tpi and im sticking with it..alot of people dog tpi's.... i wanna see what people are using with tpi... when set up right tpi's can be potent... its not all about horsepower...... here is mine... my list is long but its pretty nice setup.....
ENGINE MODS......
fresh 355 bored .30 over 4 Bolt Main Vortec Block
10243880 Gm cast Block
Blueprinted Performance build ( bored with thrust plates)
9.7 to 1 Compression
Milodon Main Cap Bolts
Eagle 5140 Forged Steel "SIR" Lightweight Connecting Rods
ARP Rod Bolts
Eagle 4340 Forged steel crank
Upgraded Clevite 77 H Bearings
Kieth Black Hypereutectic -12cc dished pistons
dura-bond hi performance coated cam bearings
Pioneer heavy duty brass freeze plugs
Internally Balanced Eagle rotating assembly (rated at 650 horsepower)
Elgin Lifters
Heavy duty flywheel
New harmonic balancer
LT1 mini Starter
Highflow radiator
High flow water Pump
ARP headbolts
Rebuilt L98 heads with manely springs, retainers, screw in studs
SA performance double timing chain
GM LT4 HOT Cam
218/228 .492"/.492" 112 LSA
Comp Cams 1.5 roller tip rockers
INDUCTION/FUEL DELIVERY MODS.....
Fully ported and Siamesed Plenum, egr walls grinded down
Fully Ported and Siamesed SLP Runners port matched to Plenum
Edelbrock Ported Highflow Intake port matched to runners
SLP's CAI with K&N air filter and SLP's special modded intake hoses
IAT relocated to SLP CAI box
48mm throttle body with Airfoil
180 thermostat
SVO 24lb Injectors
Heated O2 sensor
Crane's AFPR set at 43psi
OIL SYSTEM MODS.....
Melling 10553 Oil pump
hardned pick up
L98 Oil Pan
SUSPENSION/CHASSIS MODS......
WS6 suspension
36mm front sway bar with poly bushings
24mm rear sway bar with poly bushings
new poly sway bar links
Front K-member Braces
UMI Steering Brace
BMR Strut Tower brace
BMR weld in outer subframe connectors
Alstons weld in Inner subframe connectors
BMR non adjust Torque arm poly bushing
hotchkis Non adjust Panhard bar poly bushings
J & M Street non adjust Lower Control Arms
BMR bolt in lower control arm relocation brackets
Transmission Mods........
Built 700R4 (rated at 500 hp)
2300 Stall converter
tranny poly mount
Corvette Servo
Hardened beast Sun Shell
5 pinion front and rear Planet Gears
heavy duty sprags
High Energy Clutches
High energy Band
B&M Shift Kit
Tranny cooler
Rear End mods.........
built 9 Bolt Borq warner 3.27 Gears (rated 385hp 416Tq)
TA performance aluminum rear end girdle Cover
1/2 pint fluid increase
15 degrees cooler operating temp
ARP rear end Girdle cover Bolts
aluminum driveshaft
Neapco brute force u-Joints
EXHUAST MODS......
Hedman longtube Street headers
Custom 3" y-pipe
Catco highflow Gutted converter
Flowmasters 80’s series 3.5 inch catback
IGNITION MODS......
New distributor
MSD 8.5 super conductor wires
accel Super coil
MISC MODS.......
2 seater conversion
150lb weight reduction
tuned by PCMforless
rev limiter set at 5500rpms
New belt Tenisoner and pulley
AC delete pulley
New delco Alternator
Throttlebody Bypass delete
Oil Cooler delete
diverter valve delete
cruise control Delete
Washer fluid Delete
Cold Start Delete
Cat Delete
AC delete
EGR delete
Heater valve delete
Air delete
smog delete
Vats delete
Old Nov 14, 2009 | 08:25 AM
S10Wildside's Avatar
Re: post your tpi powerplant combos
Engine
355ci L98
GMPP Vortec Heads
GMPP 1.6 Rockers
Edelbrock Vortec TPI Base
SLP Runners
Ported Plenum
LT4 HOT Cam
52mm Electronic Throttle Body (Drive by Wire)
LS1 PCM (using 2003 Corvette calibration)
LS1 Ignition Coils (distributor-less)
Tuned with EFILive and Moates.net RoadRunner PCM
Transmission
4L60E
Old Nov 14, 2009 | 11:50 AM
88fastgta's Avatar
nice... i like how you intergrated the ls1 wiring onto the gen 1 blocks....... we have the same setup minus heads...
Old Nov 14, 2009 | 05:05 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Original Owner
Factory ordered from GM December 1988 delivered May 1989 in Vancouver, Canada.
Purchased As
1989 GTA, 5.0 liter TPI engine, T-5wc transmission and 9 bolt 3.45:1 differential
T-Tops with metallic flame red paint and beachwood tan cloth interior
Current mileage approximately 241,000km
MODIFICATIONS
Engine
New GM replacement 5.0 liter engine at 186,628km
Comp Cam extreme energy XR258HR camshaft
Ignition & Electrical System
MSD HEI pro billet distributor, blaster coil and super conductor spark plug wires
Bosch duel electrode platinum spark plugs
Optima battery
Wilson gear reduction starter
Fuel/Air Induction System
FMR EV-1 19lbs/hr fuel injectors
Holley adjustable fuel pressure regulator
Holley air foil
K&N air filter
BBK 255 LPH fuel pump
Ported plenum
Throttle body coolant bypass
Modified stock air filter canister
Hedman Hedders shorty style headers
Walker super turbo muffler
2.5" to 3.0" intermediate pipe to muffler
Cooling System
New stock radiator
Edelbrock victor series water pump
Mr. Gasket 160 degree high flow thermostat
Converted air conditioning system
Computer & Sensors
New GM computer
Custom PROM from Wester's Garage
New Thick Film Transistor MAF sensor
New IAC, EGR and ICM sensors
Bosch heated O2 sensor
Brakes & Tires
New Raybestos rotors, calipers and ceramic brake pads
BF Goodrich Comp TA radials
Steering & Suspension
Moog front and rear end links and front sway bar bushings
TDS steering brace
Edelbrock strut tower brace
Transmission & Differential
Transmission professionally overhauled at 231,713km
New Luk clutch
Differential professionally overhauled at 232,965km
New Australian 9 bolt carrier from GM
Yukon 3.73:1 gears
Ziebart rust protected and undercoated in May 1989
New metallic flame red paint
North Country fiberglass aerowing
Bosch halogen head lights
Original
Old Nov 24, 2009 | 07:10 PM
A&TZ28's Avatar
Car: 1987 IROC Z28
Engine: LB9
Axle/Gears: 9 Bolt w/3.27's
Old Nov 24, 2009 | 08:47 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
whats the point in this without track numbers or dyno numbers?
Old Nov 27, 2009 | 04:13 PM
gmsoldier's Avatar
Car: 86 Iroc
Engine: 383 MR
Axle/Gears: stock 2.73
Old Sep 30, 2010 | 05:45 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
383 ci
Forged Eagle Stroker Kit
AFR 195cc, 65cc chambers, #1034
Comp Cams XFI 274 (224/230) .573"/568" lift, 113 LSA
TPIS Bigmouth Intake, Runners, and 52mm TB, ported plenum
Dyno Don's 1 3/4" headers, Flowmaster 3" cat-back
No times or numbers yet
Old Sep 30, 2010 | 07:43 PM
Drew's Avatar
This... Without a measure of performance what good is a list of aftermarket parts?
Old Sep 30, 2010 | 07:54 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
guess ill be the first to list numbers/times
SBE 880 vortec truck motor
stock vortec 906 heads with beehive springs
scoggin dickey vortec TPI baseplate
SLP runners
BBK52mm tb
edelbrock headers+y
comp roller tip rockers 1.6 ratio
SLP 210/214 cam "roller"
3.45 9 bolt
5speed trans
full weight formula, with all power options
299rwhp/401rwtq car ran a best of 12.20 on mickey thompson drag radials on motor, and 11.29@127 on nitrous with a terrible 60ft, and spinning into second..
car was tuned/setup for spray, an all motor tune woulda net a little more power
same SBE 880 truck motor
ported vortec 906's
comp turbo cam 230/236"roller"
holley stealth ram
1.6 full roller rockers
edelbrock headers+y
363rwhp/420 something torque{i forgot} and this one hasnt been to track yet. LEAN tune of 13.8 afr{injectors maxxed}, and conservative timing 28* total
Old Oct 1, 2010 | 11:48 PM
Drew's Avatar
89fbirdformula, that's a start... With numbers it's easier to get an idea of how well it works in the real world.
Is this thread dying a quick death?
Old Oct 2, 2010 | 12:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Ok, I will add mine. Numbers with old 355ci motor. New motor should be a significant improvement. See signature.
Old Oct 2, 2010 | 01:26 PM
Keenov's Avatar
Car: 2003 Cobra
No, it was started a year ago and died peacefully. Now it's back in business.
Numbers/track times will definitely help this thread out though.
Old Oct 2, 2010 | 11:35 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
I'll post my new stuff after I get it dynoed.
Old Oct 6, 2010 | 11:05 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Well here ya go!
Old Oct 7, 2010 | 03:58 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Vortec 383 TPI- 1988 GTA-Pocket ported heads, smoothed and polished exhaust ports, ferrea valves and sized intake ports at the pushrod pinch (to prevent port stall). Vortec TPI intake, ported and sized. AS&M Long Tube runners. SLP 1 3/4 headers, 30# SVO injectors, welded and ported plenum. Custom CAI system. All induction components ported to proper CSA based on length and target peak torque RPM. 0411 PCM. Borla catback, dynotune, stock stall, 4L60-E. 10.4:1 compression. Typical bolt on mods. Makes 335 RWHP at 5400 RPM and 451 RWTQ at 4050 RPM. 30mpg@ 70mph. Needs more dyno time.
350 TPI- SLP siamesed runners, ported. Stock GM TPI base, ported. welded and ported TPI plenum. SLP shorties and borla catback. Stock rebuilt 350 TPI heads. 10.2:1 compression, LT1 cam. typical mods. Unknown how much power it made but it ran well before I pulled it.
382ci Tuned Port LT1
LE2 LT1 heads, Accel TPI conversion base, Accel runners, Electric water pump, double roller LT4 chain, 30# SVO injectors, typical bolt ons, 0411 PCM, 1 3/4" custom LT headers, custom firing order cam, Mounted in front of C5 torque tube and T-56 with custom crank spacer plate, not done yet so no dyno #'s since changes.
427ci TPI
Casting#183 Bowtie block, Offset ground 3.875" crank to 4" stroke with honda journals, custom firing order cam, FIRST TPI intake, ported aluminum heads to match. Waiting on parts from the machine shop.
335ci Tuned Port L99 (baby LT1)
similar to LT1 above but smaller. Waiting on parts to send to machine shop. I need more cash around here.
I've done lots of rebuilds and no buck/low buck mods and porting to TPI and LT1 engines. They are fun to play with.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
lakeffect2
Aug 23, 2015 08:44 AM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
