tb coolant bypass???
Old Nov 17, 2009 | 05:39 PM
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
this may be a dumb question especially cause i have already did heads cam headers and everything else on my car but how do you do the coolant bypass?????
i never understood it and i never found pics can anyone help me pleasee???
Old Nov 17, 2009 | 05:53 PM
tdavolos's Avatar
Car: 87 GTA
Re: tb coolant bypass???
I took of the TB, cut off the coolant nipples, then filled in the rest with a JB weld stick and sanded it smooth. You'll never know it was there and makes TB removal a snap. I also re did the coolant lines and got rid of the coolant bypass valve. Looks nice and neat.
Old Nov 17, 2009 | 05:58 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
basically you take that 180* elbow hose (connecting from the intake manifold to the tb) and remove it. then take your heater hose comming from the fire wall and plumb it right into the intake manifold (where the 180*elbow was). thus eliminating the tb. on mine, i dont have my heater hoses (bad heater core) so i took the hose from the intake manifold (where the 180* elbow was) and hooked it straight to the port on the radiator right below the radiator cap.
an easier method (if you dont want to get rid of some hoses) is to simply put a "connector" or whatever they call it (just a tube you can connect 2 hoses to) and use that with the exhisting hoses from the heater hose to the intake. kinda ugly having extra leangth of hoses everywhere
Old Nov 17, 2009 | 06:02 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
anyone have any pics of can take pics of their own???
oh the engine is an l98 tpi out of a 1990 corvette if that helps at all...
Old Nov 17, 2009 | 06:11 PM
tdavolos's Avatar
Car: 87 GTA
If the weather holds up i'll pop of my TB and take some pics tomorrow for you. It's alot easier than you think. Id advise getting rid of the coolant bypass valve also as they are a problem waiting to happen and look crappy under our hoods no matter were you route them.
Old Nov 17, 2009 | 06:12 PM
Drew's Avatar
https://www.thirdgen.org/coolantbypass
Old Nov 17, 2009 | 06:17 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
thanks for the link anyone have pics of it done the good way???
Old Nov 17, 2009 | 06:31 PM
tdavolos's Avatar
Car: 87 GTA
What do you mean by good way ?
Old Nov 17, 2009 | 06:37 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
the way thats not pictured in the link the way that looks better i guess and doesnt have extra hose all over the place
Old Nov 17, 2009 | 06:44 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
What is in that link and pictured is the easiest way to do a coolant bypass. Looks to me to be easy and clean! IMO.
Old Nov 17, 2009 | 06:48 PM
tdavolos's Avatar
Car: 87 GTA
When i take some pics you'll see how nice it looks not having the coolant bypass there either. I actally left it on for a while but was tired of how crappy it looked having all those hoses laying around. Now i have just one hose that runs along the top of the valve cover by the injector harness going directly from the front of the intake to the heater core.
Old Nov 17, 2009 | 06:49 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
sweet thanks i look forward to the pics
Old Nov 17, 2009 | 07:04 PM
tdavolos's Avatar
Car: 87 GTA
No problem man....It really cleans up your engine compartment nice. Plus if you run a colder thermostat like me (180) with a colder fan setting your heater wont get that hot. Now that i deleted the coolant bypass valve my heater is nice and hot. Ive owned a few 2nd gen f-body's and they never had them from the factory. GM ran coolant through the TB in case some a##hole felt like driving there TPI car through a sub-zero Alaskan winter. Neither are necesary and are a waste of space.
Old Nov 18, 2009 | 12:38 PM
tdavolos's Avatar
Car: 87 GTA
Old Nov 18, 2009 | 12:40 PM
tdavolos's Avatar
Car: 87 GTA
Old Nov 18, 2009 | 01:05 PM
tdavolos's Avatar
Car: 87 GTA
When i got rid of the heater valve i reused the hose going from the valve to the port by the passenger side manifold for it has a 90 degree bend in it... kind of. It did have to be cut so remember it will not work if you plan on re installing it the right way. They sell those hose plugs everywere and you'll need one. While there pick up a hose repair kit and DONT buy the plastic one's. All in all it will cost about 15 bucks to do what i did. As for the TB pick up a tube of Jb weld,remove the IAC valve and the plate its attached to, cut off those nipples,fill in with said JB puddy and let dry. I then sanded down the ends flush for a nice finish and put it back together. When i took those pics it took me all of 2 mins to take the TB off.
Old Nov 18, 2009 | 01:20 PM
tdavolos's Avatar
Car: 87 GTA
Old Nov 18, 2009 | 04:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you leave housing intact ,there is no need to block the coolant ports when doing the bypass as only water goes through them and you have removed that
Old Nov 19, 2009 | 01:51 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
See my post...
https://www.thirdgen.org/forums/tpi/...y-coolant.html
Old Nov 19, 2009 | 04:09 PM
Car: 87 T-Top GTA
That is some Really nice work there JDF-Z28!!!
Old Nov 20, 2009 | 01:23 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i did that today, i got a barb male to male fitting at home depot for 3 dollars brass. heater hose at autozone and clamps. I replaced the t-stat also 180* high flow mr gasket. I had a question. i noticed the gasket between the tb and plenum was upside down. it was blocking the middle hole passage on the tb. is that bad? hmm its right side up now. power.
*turns out because the gasket for the Tb was upside upon inspection. i believe that it was blocking the port vacuum to the egr solenoid/valve, canister. EEK but its better now.
Old Dec 15, 2009 | 07:38 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
When I get a chane i'm going to defenetly do this.
Tony.
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
