intake manifold torque specs?
Old Dec 20, 2009 | 12:48 PM
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
pulled the intake manifold on the vette...its an aluminum headed l98 i just need to know the torque spec to tighten it back down to..does anybody know?????i couldnt find the answer on line at all so please helpp
Old Dec 20, 2009 | 08:41 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
Re: intake manifold torque specs?
nvm i found out its 35lbs
Old Dec 21, 2009 | 07:15 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I agree, 35 ft-lbf. I torque my intake in two stages, first 20 then 35 ft-lbf.
Old Dec 21, 2009 | 08:03 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
sounds like a good way to do it, thats what imma be doin then...thankss
Old Dec 21, 2009 | 09:55 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
AND, work from the two center bolts on each side to the front and rear bolts. In other words, get the sequence correct. Another AND, get a smear of silicone sealant on both sides of the gasket and a good tab at the corners where the heads meet the block & intake.
Old Dec 21, 2009 | 10:58 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
rtv black yeah???and then i can you permatex 2 for the bolts
Old Dec 22, 2009 | 06:01 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
i just noticed i had 8 short bolts and 4 long ones for my manifold and i didnt label or remember where they went lol
so i would assume the shorter ones go on the outside of the coolant passages...is that right??and will it make much of a difference if i did it a different way?
Old Dec 25, 2009 | 10:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
The smear of silicone that I am talking about goes where the coolant crossover is on the intake manifold. Remember just a smear. I am not familar with your intake; the location of the longer bolts should be fairly obvious. Do you have a remote coil to mount or some other device?
The silicone sealant should say "safe for O2 sensors" or something similar.
I do put silicone sealant of the bolt threads also. All of them.
Old Dec 27, 2009 | 10:07 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
everythings done and still no leak so i am very happy
deracer
Apr 11, 2016 12:04 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
