What are you guys using for an air boot with 52mm and bigger TB's?
Old Mar 11, 2010 | 11:17 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So the stock air boot does not fit over the 52mm throttle body from BBK. Just wondering where those of you that are running one were able to source a boot, or reducer, or some type of connector. I plan on running a custom setup eventually, but for now I still need to keep it looking semi factory to get it past the emissions inspection. I was thinking about getting a black metal elbow like the one trick flow makes. Thoughts?!?! Thanks guys
Will
Old Mar 12, 2010 | 05:59 AM
S10Wildside's Avatar
Re: What are you guys using for an air boot with 52mm and bigger TB's?
If I recall correctly, years ago I ran the Camaro boot off of a 52mm BBK throttle body. It required stretching, but it fit. Might want to try a heat gun to warm the boot.
The aluminum LT1 elbow will cause clearance issues with the front accessories.
Old Mar 12, 2010 | 07:26 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I run the stock boot with a BBK 52mm TB; just lube the lip of the boot and / or throttle body with grease ( I use "Krytox," from a swimming pool supply store, it's great for lubing and protecting just about any rubber or synthetic o-ring) or spit, and work the boot back and forth or around and around onto the lip of the throttle body.
Bill
Old Mar 12, 2010 | 12:18 PM
norcalz28's Avatar
right on fellas, I'll give it a try
Old Mar 12, 2010 | 08:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old boots do not have the flex to fit over the lip on the BBK that the stock TB doesn't have.
Worst case file the lip off ; the boot is retained by the clamp anyway as per stock
Old Mar 12, 2010 | 08:23 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I have a 58mm BBK with a custom built airbox, but the connection inbetween is a silicon boot. Got it at a fluid connector store locally. I'll get some pics in a bit tonight for you, the boot cost 25 bucks, and fits perfectly. It was 4 inch in diameter I believe.
Old Mar 12, 2010 | 08:56 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
I would like to see pics, don't forget
Old Mar 15, 2010 | 12:15 AM
norcalz28's Avatar
FYI, I used a little "rubber care" and the phacker slipped right on. Thanks guys
Old Mar 15, 2010 | 07:25 AM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Rubber is a non-newtonian material. It'll stretch when cooled and shrink when heated. Heating it before trying to stretch it on won't work. An old engineer showed me this once while trying to fit rubber hoses on a compressor. Just toss the part in the fridge before you want to put it on.
Old Mar 16, 2010 | 06:56 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Boot is plastic , not rubber
Old Mar 22, 2010 | 01:22 PM
Engine: L98 494hp
I forgot my pics, lol...but will get them back on tonight, wrote myself a note to remember.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
Street Lethal
Aug 14, 2015 08:25 PM
bryan623
Aug 10, 2015 11:33 AM
