Rounding out the HUMPS on the intake plenum holes/does it help performance?
Old May 5, 2010 | 08:52 PM
edpontiac91's Avatar
Car: 1991 Formula 350, 2002 Grand Prix G
Engine: 350 with SLP & Edlebrock mods
Transmission: 4-speed automatic-700 R4
Axle/Gears: 10 bolt with 3:73
What is the purpose of those HUMPS in the bottom of the 2 round intake plenum holes (just behind the throttle body)? I was told they were there to reduce the incoming air from raming to the back of the plenum and leaning out the front two intake runners. I also was under the impression that if they were ground down, it added to the CFM air flow and improved performance. I have never seen a report of a before and after this was done to see if it really works or not.
Old May 5, 2010 | 10:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Rounding out the HUMPS on the intake plenum holes/does it help performance?
It works
http://www.austinthirdgen.org/index.php?pid=21
Old May 6, 2010 | 09:42 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Any noticeable performance gains?
Old May 6, 2010 | 11:58 AM
That was part of original question, has anyone done this with before and after 1/4 mile runs? I have to imagine that GM put those HUMPS in there for a reason, but so far nobody has an answer for this.
Old May 6, 2010 | 02:22 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
The single thing Ive notice was my car pulls hard to 4800 where it started to fall flat around 4200 rpm with the stock unported
Old May 6, 2010 | 02:35 PM
Car: 1988 GTA
Right on. I think I will go ahead and port mine since it's off right now for an injector swap anyway. I will post results when I'm done.
Old May 6, 2010 | 04:41 PM
RedKnight79's Avatar
Car: '91 Pontiac formula
Engine: 350 tpi
Transmission: Th700R4
I noticed a better throttle reponse when I did mine a long time ago
Old May 6, 2010 | 04:53 PM
Damon's Avatar
Like anything else, on a stock motor there is probably very little to be gained. On something that's going to breathe a little deeper the details become more important.
My personal belief on why they were put there by the factory is they were trying to keep the carbon and other nasty stuff that's in exhaust gasses from having too direct a path to glue themselves onto the back of the throttle plates. Not that they don't get choked off pretty bad after a while anyway, but that's the kind of stuff that causes warranty headaches for a manufacturer.
Old May 6, 2010 | 07:40 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Damon
My personal belief on why they were put there by the factory is they were trying to keep the carbon and other nasty stuff that's in exhaust gasses from having too direct a path to glue themselves onto the back of the throttle plates. .
Anti reversion dams for the EGR ports
Old May 6, 2010 | 08:21 PM
In layman terms, what the hell it that?
Old May 6, 2010 | 11:16 PM
BadSS's Avatar
You're looking at about a 100cfm increase through the T/B with the EGR wall removed - allowing the t/b to flow near full capability. I saw a flow comparison where the stock t/b with the EGR wall removed flowed more air through the plenum than a 52mm t/b with a stock plenum. This is one of those mods that increases airflow enough that it requires an AFPR or some other means of increasing the fuel for proper air/fuel ratio under WOT. Expect very little gain porting the plenum without adding the fuel. If you do it right you should expect to see around a .3 et drop and close to 2mph increase on a stock combination in good health,, or about three car lengths in the 1/4 mile. More modified or larger engines could be a bigger gain.
Old May 6, 2010 | 11:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What Damon said ; walls to stop the EGR gases going forward to the butterflies
Old May 7, 2010 | 09:33 AM
Car: 1988 GTA
Okay so I was ready to tear into my plenum but did some last minute searching. I found some older threads where some people claimed that removing the egr walls causes a decrease in torque. I don't understand flow dynamics well enough to understand how this would effect hp and torque numbers. Could somone please explain what effects removing the egr wall would have on hp and torque output. Thanks.
Old May 7, 2010 | 10:17 AM
F-Body Demon's Avatar
I lost throttle response but gained top end. Im sure it can be fixed by tuning. After I added an airfoil I was back to stock throttle response and kept the gain.
Old May 7, 2010 | 10:34 AM
Car: 1988 GTA
Any noticeable loss in torque?
Old May 7, 2010 | 10:58 AM
Off the line, yes. Up top, no. But considering I couldn't hook the car in the first place I didnt really mind a slight loss in TQ. And I mean this was very slight...hardly showed up on the butt dyno.
Old May 7, 2010 | 11:07 AM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
kind of the same loss of low end you get putting to big of headers on a car. I put the 1 3/4 SLP's on my 305..low end went to hell..but up top is a diff story. I believe it all has to do with velocity; which is why he gained it back when he added the airfoil. Remove those walls, the air doesn't fill as aggressively ( my understanding) but feeds more volume which helps the top end.
Old May 7, 2010 | 12:00 PM
Car: 1988 GTA
Okay I guess that makes sense. I probably won't do anything too drastic then. I like having a torque monster. Thanks for explaining.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Magman
29
Sep 12, 2015 10:41 PM
DJanes97
Sep 1, 2015 02:55 PM
Thaney9
Aug 29, 2015 03:16 PM
TreDeClaw
Aug 14, 2015 06:58 PM
