which is better 383 or 408 tpi
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: which is better 383 or 408 tpi
Neither.
Both are going to be severely restricted in breathing with a stock TPI.
Some guys run modded TPI's on 383 ; awresome bottom , pull stumps out all day end but nothing up top.
Remember a stock 350 TPI is dead at 4500 so a bigger cube engine would run out of puff sooner.
Read link below to see what intake change does on 383
http://www.compcams.com/Community/Ar...?ID=1737510521
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
what you would have to do is port an aftermarket intake and aftermarket runners.... it's the only way, however, some say that even then you will not have the full benefits of your engine... well I think 400 RWHP is enough, don't you think? ... the way I'm thinking of going once my 383 project has funds to work with, is I am gonna go with a Edelbrock Hi-Flow intake, and AS&M runners... I have emission testing to worry about... so if the intake has a CARB EO number, I think I should be able to pass with the runners... they look somewhat stock..
Car: 91 gta ws6
Transmission: 700 R4 TRANS
i guess it would be enough i just want to give the challengers and camaros hell its going in a 1980 pontiac lemans
Car: 1986 IROC
Engine: 355" TPI
The 383 is a better size for TPI. You will need to port it quite a bit but you should be able to make good power. Remember to match your cam to the RPM range of TPI, so nothing peaking over 5000.
Engine: 5.1 4bbl
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Welcome to the TGO Universe!!!!!!
A TPI intake was made to produce Tq in the first place, and it does this very well.
vetteoz is right when he says that the 350TPI is done by 4500 RPM.
But may I ask.... what's wrong with that???
Maximizing overall USEABLE POWER always results in a quicker car.
Nothing wrong with making an engine with 600hp, but if you need to spin it at 7000RPM to get there it's not a street car....and I don't think it's fun IMO because you'll be hard pressed to Rev like that in a street car
I'll argue that making great power under 5000 RPM will always be a great street car that always has power on tap.
I'm struggling with the same decision right now....
If you're making 500+ ft/Lbs of Torque from 2000-4500 RPM who are you losing to? As long as you have another gear to shift into..... Now you won't have HUMOUNGOUS HP #'s to brag about, but who cares when you lift the tires off the ground???
By the way....What gear ratio are you running in the back? Turbo350 tranny right?
Don't get me wrong.... a big inch small block is gonna need a large aftermarket TPI setup!!! and great flowing heads to say the least.... But I think that you'd have a blast with it.
How's that for starting a discussion....
I'm gonna sit back and watch the fireworks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The most important thing to remember in building a motor....
Cyinder filling, it takes air and fuel to make power and torque.
If the intake system won't allow enough air, you're not going to get HP & TQ.
Your basic base manifold will not work with a displacement over 355 CI.
We have got them to flow a little over 300 CFM and that works, but is marginal for 383.
At 300 CFM the RPM range max is about 6200-6400
HTH
HTH
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
A 383 with the Mini-Ram or Stealth Ram can produce damned good numbers for a street car. Stock TPI is just too limiting.
Car: 91 gta ws6
i also have the efi connection wire harnsss with the ls1 computer so hopefuly that should also squeez out some hp and gas milleage
Car: 91 gta ws6
Car: 91 gta ws6
Car: 87 GTA
Car: 82 Z28
Transmission: T400
Even the aftermarket TPI style intakes are stop making power @5K but make impressive torque down low
Car: 91 gta ws6
those torq and horsepower figures from the comp cam intake shoot out does not seem too limiting for a street engine to me.436hp and 534ft of torq and a 383 is very impressive.but it would be even more powerful with a 408 tpi sbc even a 400.
Show me how to make that kind of power and torque under a stock TPI plenum and runners then. People don't often see those kinds of numbers even on ported setups and in some cases not even with a Mini-Ram/Stealth Ram/Super Ram. If I could make that kind of power with the stock TPI setup, then I'll definitely do that. I love the way TPI looks.
Car: 87 GTA
I actually have that issue in print, sitting right here beside me.
I just can't find anybody that knows which specific heads were used. Only the manufacturers name.
Car: 91 gta ws6
how your engine is tuned plays a important part.the cyclinder heads.compression ratio, injectors, full roller rocket arms will help you get that type of power and power ignition system,throttle and the runners you use.swicth over to a ls1 ecu to control the motor on a 408 or 400 even 383sbc you will see a definite power gain vs a flashed or stage three e prom
Car: 91 gta ws6
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
vetteoz has already posted a link to the article twice in this thread. Post #2 Post #17. I guess third time is the charm.....Here it is again.....
Car: 87 GTA
Car: 91 gta ws6
Car: 87 GTA
Look at what the Extrude Hone & large tubes did.....Good gains, but they still works great for ME.
Everyone has different goals. The stock upper end is perfect for ME & possibly for 87WS6 too. My goals steer me towards stock upper end & leaves me $ to spend elsewhere.
On the top end, yes. Everybody has always known that. How much $$$ did the extra 100hp cost? Wasn't cheap. Look at the hp and torque curve, not just the highest # achieved. Besides.....Highest possible hp #s are not everyone's goal. Low RPM is what moves a street car, not horsepower. Give me the the low RPM for my street car.
Look at what the Extrude Hone & large tubes did.....Good gains, but they stock still works great for ME.
I saw the curves and do agree that the stock TPI setup had a nicer looking curve. That could be because then the heads and cam they were using were not up to par with the miniram setup. This is where building an entire motor to match eachother comes in.
I also wasnt trying to come off like the stock setup is worth nothing. If its good for your motor and what you want out of it, then thats great. Saves you money. Everyones motor (besides all out race motors) have some power they could gain somewhere by switching out something. I was just pointing out that just because a stock TPI setup CAN make 400+ horsepower, doesnt mean its not restrictive in some form.
Car: 91 gta ws6
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. The 408" (.040" overbore, not " .080" ") will, hands down, make more torque than the 383"... the stock TPI tuning cuts off HP about 4500 RPMs for 350, 383, 400, so the more torque you have by 4500, the bigger HP number you generate...
.. If you don't have to worry about emissions testing, the Accel/Lingenfelter SuperRam, Holley Steet Ram, Mini-Ram, or even an inexpensive used tunnel ram base modded with your plenum, injectors, and throttle body added (TPI = Tunnel Port Injection here) will make the most HP power and even great torque...
Car: 91 gta ws6
yea so far i got the pro flo xt with a ls1 tb dont know how would do but it should be better than the stock intake
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
OP theres your answer if you have to have a TPI style intake for the money its a bargain..
NEVER going to happen with a stock TPI intake, ever.
Throw that stuff in teh trash where it belongs and start with better parts.
383/400+cubic inch engines are air hungry and demand a lot.
Car: 91 gta ws6
Car: 1989 Trans Am GTA
Transmission: M28 T56
The TPI car would feel better all around town and in all part throttle situations because the revs would stay below 4000rpm. But once you put your foot to the floor and the engine heads north of 4000rpm the TPI is going to feel SLOW compared to a HSR. This is a stock TPI intake vs HSR comparison here.
My LT1 shifts at 6k, and the recovery with a 700r4 is about 4700rpm-5000rpm depending on the gear.
Engine: 4++,350 & 305 CIs
build the 408, use a solid roller monster heads 220-240cc intakes and a mini or HSR. Stomp the competition.
Stroke and gears move a street car also.
I spin my 400 ci unit to 8k all the time. its a street car.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I went a 12.20 a few years ago with completely stock, unported intake and runners on a 350 with just afr heads and comp 276 with the stock computer chip. Shifted at 5700. Had more in it with tuning, etc..... The pic in my sig was taken with that setup. I think that would handle most new challengers and camaros. Just sayin.....
Transmission: Many
Axle/Gears: Many
.. Unfortunately, the new Challengers, and especially the Camaros, also go quicker with slicks on them...
Transmission: Many
Axle/Gears: Many
.. The Eddy ProFlow is one of the intakes tested in the Super Rod tests sticky thread above... it didn't fare too well compared to the others (except stock TPI)... I've seen it tested in other places and it did even worse (like 360HP max)... But I don't know why, seems to be about the same short runner design as the Holley Stealth/Street Ram, so I don't understand why it's not performing about the same, at least HP-wise...???
Car: 91 gta ws6
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
