Want to put 350 TPI in my '91 Firebird Vert.
Old Jun 13, 2010 | 08:07 PM
gfranklin2308's Avatar
Car: 1991 Firebird Convertible
Engine: 3.1L V6
I have a '91 Firebird convertible that I just bought. It has the 3.1L V6 in it. I want to swap with a same generation 350 TPI engine. Are there any pointers out there that can help me do this the right way. I am new to engine work, and want to do it right as its my daily driver. Should I start with a short block and build up from there. Should I try to find one out of another 3rd gen. If so what do I need to look for to match up to my '91 V6.
Thanks in advance for your help. This website rocks!!!!
Old Jun 13, 2010 | 08:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Want to put 350 TPI in my '91 Firebird Vert.
That is going to take some work. Need new engine wiring harness, ecm, exhaust, fuel pump and a host of odds and ends. Maybe even a new transmission/rebuild. I don't think the V6 auto has the same number of clutch pads as a V8. Just a whole list of things to think about.
Old Jun 13, 2010 | 09:14 PM
Engine: 3.1L V6
Is there another swap that would be easier? I like the idea of keeping the 3rd gen engine in the car. Staying with the TPI instead of the LSX. I understand that it wont be super easy or inexpensive. I just want to make sure its the right thing to do. If the LS1 swap is better, I just found a newly rebuilt one out of a '93 vette that I can get for $800.
thanks,
Old Jun 14, 2010 | 12:12 AM
MrPink's Avatar
Car: 1991 Pontiac Trans Am
Engine: 305 TPI 5.0L
twin turbo your 6. Might even be cheaper. Or do a LS1 swap. You can find one from a wrecked fourth gen.
Old Aug 5, 2010 | 06:53 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Hey your from Lafayette Indiana, I was texting you about your car awhile ago when you had a craigslist ad up about wanting to put a v8 in your car.
check my car out I just bought 2 weeks ago
Old Aug 6, 2010 | 01:05 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
thanks,
That would be an LT1.
Old Aug 6, 2010 | 01:35 PM
Drew's Avatar
You can read up on the V6 forum... What you'll find out is the V6 is really a dog short of expensive modifications. Next hit up the engine swap forum... What you'll find out is that any V8 swap is going to involve so many parts you'll practically need a running parts car to do the job.
One of the reasons LS1 swaps are so popular is because they really don't require much more effort then a TPI swap. Also there are more mechanically sound, used, LS1 donors out there then TPI donors. Most 82-92 drivetrains are worn out. By the time you get done rebuilding an 87-92 L98 and the 700R4 to go with it, you'll spend as much as you would on a used LS1. Better yet the LS1 will almost definitely perform better.
Old Aug 7, 2010 | 10:06 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
If this a daily driver your first step would be to make sure you have a way around town ya know school/work/home that sort of thing cause this will more than likely take more than a weekend.
Old Aug 8, 2010 | 07:58 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I would think that the amount of money it would take to do that conversion you could hunt down a decent third gen with a 350 already in it and keep the vert the way it is.
Old Mar 20, 2011 | 05:33 AM
transtech1961's Avatar
i just bought a 91 firebird with t-tops 305 t.p.i and 700 trans engine is shot i have a rebuilt 64 corvette 327 i am trying to make work what injectors and size throttle body is reccomended for this swap. the 327 is .030 over bored and a mild cam 420/420 lift any input would help ty
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
