another "this cam?" question...
Old Jul 29, 2010 | 05:37 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
been looking for a new cam to beef up my gta a tad and came across this one on Jegs..questions
will it work?
improvemets?
Mikey
http://www.jegs.com/i/Lunati/638/60103/10002/-1
Lunati 268 VooDoo
Old Jul 31, 2010 | 02:49 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: another "this cam?" question...
TTT
Old Jul 31, 2010 | 09:09 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What else is currently done to your car now? That cam would probably need some PROM tuning to see a real gain in power. The LSA angle of that cam is 110 which is low for a fuel injected car. Also, you picked out a flat tappet cam. Your motor is a roller cam motor. The flat tappet will work in your engine, but you can make more power by going with a roller cam.
Old Jul 31, 2010 | 09:27 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ohh..i see
i have 1 7/8" headers, exhaust and its tuned..
so what kinda cam should i get??
Old Jul 31, 2010 | 09:45 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
It will need to be retuned after changing the cam, whatever you end up choosing.
Old Aug 1, 2010 | 01:56 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
noted
Old Aug 1, 2010 | 03:26 AM
thegooseman's Avatar
Car: 1992 RS
I didnt know a flat tappet cam could work in a roller motor.
I take it you have your stock heads? If you do they will choke it out. You would need to get new valve springs in order to handle the extra lift and that cam has.489''/.504''. I believe the stock heads max out at .480, and anything more than that you may need to get the heads machined. Im sure somebody will chime in to fill in the gaps on what Im talking about.
Old Aug 1, 2010 | 03:32 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Dont put a flat tappet cam in a roller block... you leave a lot of power on the table doing that. And you lose long term durability and reliability. Gotta worry about oils, break in, wiping a lobe at some point... tappet metal wearing and depositing itself into bearings... etc.
If everything goes well, the mount of metal that wears off is minimal, but def not zero. Dont skimp on the oil changes.
Old Aug 1, 2010 | 03:37 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
sorry..guess i didnt mention it :P
IM DITCHING THE LUNATI CAM ALTOGETHER!!! LOL
so...with my stock heads and mods listed above..Whats a good cam for my car? dont want it too choppy...
Old Aug 1, 2010 | 04:19 AM
Car: 1992 RS
Ive been told the ZZ4 cam is a nice upgrade. You can run the stock tune with it but of course to get the full potential of the cam a tune is in order.
Old Aug 1, 2010 | 12:27 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
alright ill look into that one..thanks!!
Old Aug 1, 2010 | 01:02 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Originally Posted by itsMikey
ohh..i see
Not to bust your ***** bro, but you have 1 3/4" headers, not 1 7/8"
Old Aug 2, 2010 | 08:32 AM
Z28TT's Avatar
Car: 1992 25th Heritage Z28TT
Engine: 400ci Stealth TPI Twin 58mm Turbo
Transmission: Tremek TK-600
Axle/Gears: stock
if your TPI still has stock runners, plenum, and throttle body, you do not need that much cam, typically TPI falls on its face around 4800 rpm, and is designed for low end torque. I would not suggest that much cam unless you are going to do more to the engine to get the umpf outta that cam.
Im running 276/280, .502/.520, 113 degree separation. Its actually a marine application, but for twin turbos, I wanted the big separation for less overlap under boost, and high revs. I run a Holley Stealth Ram with Brodix RT heads, and this cam is good to 6200 rpm.
Old Aug 2, 2010 | 11:55 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
i knew that lol...
soooooooooooooo wut cam?!?!?!?!? ahhhhhhhh
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
