1990 iroc 305 tpi injectors install
Old Aug 19, 2010 | 06:04 PM
samanatoo's Avatar
ok new bosche three s are ordered from southbay now i have been briefed on how to install the injectors correctly and to prime the system for leaks etc.
question is do i have to take the whole tpi setup off or just the side runners?
my car is a 1le a/c delete. any help would be greatly thankfull. this has been a very helpfull site!!!
Old Aug 19, 2010 | 07:16 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: 1990 iroc 305 tpi injectors install
remove the upper plenum..and the side runners,and you can then change the injectors..
little trick, i actually use a flathead screwdriver to remove the torx bits on the BOTTOM side of the runners..by the valve covers..
if done right, theres zero chance of the torx stripping, and it takes me 15 minutes to get an entire tpi intake off..
using this method saves from needing to remove the valve covers.
also, if you have never done it before...
there are 2 bolts that go from the INSIDE out,that are under the plenum, make sure you get those two, ones at the front, others at the back
Old Aug 19, 2010 | 10:12 PM
samanatoo's Avatar
thx I removed all of the bolts tonight. I see that the plenum has to come off 1st then I can see one off the two inside bolts that hold the runners. I will continue tomorrow. the injectors will be here by Sat.
Does the plenum just come off easy after you break the gasket seals from the runners? Is there anything else beside hoses and plug ins that keep the plenum from coming off?
Old Aug 19, 2010 | 10:20 PM
On Probation
there is the connector on the bottom for the air inlet temp sensor, so dont yank to hard..
other then that, no, its just vac lines and booster lines
also, if you pull the tb with it, you'll need to remove the coolant lines from the tb, if there still attached.
the front inner bolt, the head faces the drivers side, the rear runner inner bolt head faces the pass side, and is next to the dizzy cap.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
