will the car run with these unplugged (pic)
Old Sep 22, 2010 | 08:00 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
This car has not run in a couple of years. 1989 forumla 350. the owner said the car ran when he parked it. I noticed these 2 sensors are unplugged.
I dont see the wires. I was going to try and start the car. Will the motor run without the sensors plugged in?? I know some motors will not stay running when some sensors are unplugged.
its the 2 in front of the lower part of the intake.
Old Sep 22, 2010 | 08:05 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: will the car run with these unplugged (pic)
cant tell by that pic...circle the area?
looks like TPS/IAC/compressor are all hooked up correctly..
if you are talking about the 2 wires to the left in the picture by the hot water bypass valve, take a picture of what the connectors look like..only other thing in that area for wiring will be the AIR connectors, and the CTS connector.
Old Sep 22, 2010 | 09:02 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
marked in red
Old Sep 22, 2010 | 09:05 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Old Sep 22, 2010 | 09:12 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You sure it's an 89?
the small sensor is the temp sensor for the ECM, this is what the ECM uses to control the fan, timing, and fueling of the motor.
the other looks like a Cold Start Switch, but they removed that on the 89 TPI cars.
Old Sep 22, 2010 | 09:16 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
As far as I know.
Old Sep 22, 2010 | 09:22 PM
On Probation
what he said...
either one unplugged will probably allow it to run, but it will run terrible.
get them fixed and replaced asap.
Old Sep 22, 2010 | 09:33 PM
Drew's Avatar
-deleted
Old Sep 22, 2010 | 09:34 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
So how do I find out if parts have been mixed up on this TPI??
And How Do I find out if its still the 350 engine??
Old Sep 22, 2010 | 10:35 PM
Guest
Guest
Posts: n/a
You'll need the casting number off the block. A lot of people say to read the one in the back driver side behind the head but IMO thats a real PITA to see on most cars. I find it easier to get the 3 digit numbers off the side of the block. The original 89 block has a 638 cast into the side, they're about 1" tall right in the middle.
As far as the cold start switch is concerned... if it starts fine without that connected then you have no worries. You NEED the CTS hooked up. Thats the smaller of the two, closer to the middle of the engine. It looks like the connector is busted off too, so a replacement sensor is in order.
Old Sep 23, 2010 | 11:18 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Pulled the motor today. I did not have a chance to try and start it. I may have it sold tomorrow. The back of the block says 5.7. the intake does not have a CSI, so I guess that plug may have been just added for whatever reason. This is where the CSI would be right??
Old Sep 24, 2010 | 01:04 AM
Drew's Avatar
-deleted
Old Sep 24, 2010 | 02:22 AM
Zepher's Avatar
Originally Posted by Drew
All TPI valve covers up until 1992 are silver. It looks like you've got a cobbled together engine. The intake is probably off an earlier car.
just some fyi,
I saw a 92 Formula 350 at our show last Saturday, original owner, bone stock, built January 6-8, 1992 and it has Silver valve covers.
Not sure when they switched to black valve covers, as my friend has a 92 Trans Am 305 built in June of 92 with black valve covers.
Old Sep 24, 2010 | 03:04 AM
TwinTurboROC's Avatar
yes thats where the cold start is supposed to be, drivers side runner
edit : just noticed the manifold bolt is a hex head bolt, not a torx head bolt
Old Sep 24, 2010 | 05:00 PM
Drew's Avatar
-deleted
Old Sep 24, 2010 | 10:39 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Well you guys got some good eyes. Upon further inspection, I found the motor to have been replaced with a 90 n up motor n trans Seem the motor was rebuilt and they could never get it running right. Now I know why it sat so long. Im going to tear it completely apart and give it a gasket overhaul. Well see what happens from here.
Check out how clean this is!!
Old Sep 24, 2010 | 10:41 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
Look at this cool bird I found on the side of the road
Old Sep 25, 2010 | 04:34 AM
Drew's Avatar
-deleted
Old Sep 25, 2010 | 07:05 AM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
i need to find that trans am boot for the tpi!!!!
Old Sep 25, 2010 | 04:21 PM
snowflake's Avatar
Car: 91 camaro
Transmission: auto
Axle/Gears: ????
TBI truck heads... Did you check the casting numbers on the block yet? It's probably a truck engine with the TPI thrown on top.
No but it does say 5.7. I was thinking it was just a junkyard pullout also.
Do the truck heads suck?? Would posting the casting #'s help?
Old Sep 25, 2010 | 04:27 PM
On Probation
yes, any and all TBI heads royally blow!
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
