Car Stalled wouldn't start for around 30 min.
Old Oct 11, 2010 | 09:51 AM
Stratocaster25's Avatar
Car: 1992 Z28
Engine: LB9 305
I took my Z28 for about a 30 minute drive this morning to run some errands and when I went to start it up to go home it started up fine. I backed it out of my parking spot and went about 20 feet and it stalled and wouldn't start. I sit and tried to start it for about 10-15 minutes before finally giving up and calling AAA. While trying to start it I never smelled any gas, so I didn't think I was flooding it. It just clicked. I doubt it's the starter because I just had a new one installed last summer. When I got it home and in the garage I let it sit about 30 minutes and it started right up. When it stalled the service engine soon light came on, so I checked it out and it just kept throwing the "12" code over and over, so I'm not getting any kind of code. It did this a couple of years ago but ran fine ever since. Anybody have any ideas?
Old Oct 11, 2010 | 01:19 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Car Stalled wouldn't start for around 30 min.
Mine used to do that all the time, the starter would get heat-soaked, it wouldn't start again for 30-40 minutes sometimes. The starter is subjected to extreme heat because of where it is, practically on top of the exhaust pipe.
Old Oct 11, 2010 | 01:32 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
so it didn't crank right? nothing no sound? if that's the case, as mentioned above it's your starter solenoid getting heat soaked... this is especially true on cars with headers... I had that problem with my bird and ended up wiring an old ford solenoid up by the battery to bypass the starters solenoid... never again have or did I have that problem..
Old Oct 12, 2010 | 06:24 AM
Car: 1992 Z28
Engine: LB9 305
It made a clicking noise when I tried to start it. I didn't smell any gas, so I knew it wasn't flooded. I talked to a guy at work today who works on cars and told him what it was doing and he said he thought maybe it might be a battery problem. He said to check the terminals and make sure they're clean and secure. He asked me if I was running anything while I was driving and I told him that I had the vent on. He said that if I had a bad connection or a weak battery that maybe it was drawing power from it. He also said that maybe the alternator could be bad as well. I do go through a lot of batteries. I drive my car from May to Nov and keep it stored from Nov to May and it seems that I always have to put a new battery in it every year when I get it out. Does this sound like a possibility or do you guys still think it could be the starter getting too hot?
Old Oct 12, 2010 | 11:57 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
the clicking noise in its self most of the time leads to a bad battery... when you store your car, do you disconnect the battery? if you don't, you may want to start doing that... also checking the acid/water levels of the battery to make sure they don't get low... on the starter I not so sure anymore, since you say you get a clicking sound...
Old Oct 12, 2010 | 01:01 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Be sure to check all battery cable connections along with having the battery tested. Battery cables lead a harsh existence and are often overlooked. They can also fail internally, breaking inside the insulation where you cant see it. A volt drop test from one end of the cable to the other, while cranking, will find the break.
Old Oct 12, 2010 | 01:46 PM
Car: 1992 Z28
Engine: LB9 305
I've never disconnected the battery when the car is in storage because I like to start it up from time to time and let it run for 10-15 minutes. Every year when I get the car ready for summer the battery is always dead. I hook it up to my charger and it never takes a charge and I end up having to exchange it for a new one. Maybe I'm just getting crap batteries.
Like I said about 15 minutes after getting it towed home it started. It didn't fire up as fast as normal, but it did start. When I got home from work this morning I tried starting it up and it fired up just as fast as it normally does.
Old Oct 12, 2010 | 01:49 PM
Car: 1992 Z28
Engine: LB9 305
I checked the cable connections this morning and they're secure with no acid build up and the cables are probably only a year old. I know that doesn't mean they can't be faulty, but they're not the originals. I may throw the charger on the battery for a few hours. I'm also thinking of taking the car to autozone this weekend and having them test the alternator.
Old Oct 12, 2010 | 03:11 PM
bjn's Avatar
bjn
You should use a trickle charger while you store the car. It will keep the battery conditioned properly.
http://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
Read about the Sulfation.
Check the voltage of the battery before and while starting.
Old Oct 12, 2010 | 05:24 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Cool. Do check the connections to the block and starter though.
Old Oct 13, 2010 | 06:35 AM
Car: 1992 Z28
Engine: LB9 305
I checked out that link you provided and it does make some sense as I do tend to let the car sit for long periods of time without driving it. I've had the car for 4 years and I haven't even put 1,000 miles on it! Even during the summer months I may only get it out once a week. I was a little busier at work this past summer so it was driven even less. How often should I put the charger on the battery while the car is not being used?
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
drathaar907
Aug 6, 2015 04:20 PM
