88tbi swap to 90-92 sd tpi
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
hav a 88 camaro with 305 tbi and i bought a 90-92 305 tpi sd setup complete with wiring harness and computer will i hav any wiring isuses if i put it in i didnt get any of the vats system with the harness so will this be a problem any help please
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Re: 88tbi swap to 90-92 sd tpi
ok so the swap is almost done motor is in the car fuel pump changed, i bought the vats bypass moduel and i'm still not getting any fuel got any suggestions
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Bolting a '90-'92 harness in an '88 won't work, pin locations are different.
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
i kno pins are different i repinned the c100. the c207 under the dash is a little different. can't find any diasgrams on the 207 for the 88 sure it can be done just need some help with the wiring if anyone has the diagrams i would sure appreciate some help the fuel pump comes on and getting fuel to the rail but i dont think the injectors are opening
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
ok i just tested the injectors with 2 wires going to the battery i kno thats a bad thing but did it anyway and they do not click so i guess they are stuck closed.i hav another set of injector that i am going to put in they all click when the car is cranked hope this fixes it
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
well put the other injectors in and it fired right up now just have to get everything buttoned up.also have to order the vss with the manual cable so my speed odo works
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
well car is running now my oil gauge pegs out when the car starts and the volt meter isnt reading right should i rewire the altenator the way it was with the 88 tbi
Sanjay
Aug 12, 2015 03:41 PM
