Another 355 TPI car lays down big #'s
Old Dec 1, 2010 | 10:55 PM
  #151
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: Another 355 TPI car lays down big #'s
Man you guys are making me so jealous! I can't wait to get my 355 going. I am still debating on stock or 3.750" crank.
Seeing these results really make me want to $ave the ca$h. I tried to keep the car stock, I can't do it.
Old Dec 1, 2010 | 11:19 PM
  #152
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Originally Posted by 1989GTATransAm
Back to Orr's car for comparison.
My 355 motor was putting down around 370rwhp. My race weight was right around 3700 pounds. Car, heavy GTA 3440 and me at 260.
So let's say in comparable air my car went 12 flat. Take away 250 pounds and we are down to 11.75. Add 25 horsepower to my motor and we are down to 11.5 sec. Very comparible to Orr's numbers of 11.4.
Question for you, that 370 you put down was that the same dyno that everyone went to this time around?
Old Dec 1, 2010 | 11:36 PM
  #153
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Same dyno. I was there
Old Dec 1, 2010 | 11:39 PM
  #154
Guest
Guest
Posts: n/a
Should have been. The pics from this dyno day look like the same place to me.
Old Dec 1, 2010 | 11:48 PM
  #155
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Does anyone know if Topteam had his factory ECM and wiring harness setup, or was it Aftermarket? Beautiful work down there fellas.. got me thinkn bout not strokin my block now.
Old Dec 2, 2010 | 12:19 AM
  #156
topteam54's Avatar
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
I had factory GM ECM and harness, its been converted over to speed density by Don and tuned by Kevin.
Old Dec 2, 2010 | 01:34 AM
  #157
Copchaser's Avatar
Are u running the 67cc twisted wedge tricks or no?
Old Dec 2, 2010 | 07:00 AM
  #158
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Nope
Old Dec 2, 2010 | 10:17 AM
  #159
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
See the full story and pictures here on the manifold work:
https://www.thirdgen.org/forums/tpi/...e-porting.html
Old Dec 2, 2010 | 07:45 PM
  #160
topteam54's Avatar
No I don't have the twisted wedge. I'm running the 195 kenny duttweiler heads. Which I might be doing a head swap soon. So these heads might be for sale pretty soon.
Old Dec 3, 2010 | 05:42 AM
  #161
Copchaser's Avatar
Awesome setup man.. mine will be identical to yours, but with the Brodix IK200s.. Should be in your hp/tq range. Im excited. THanks for all your info.
Old Dec 3, 2010 | 06:30 AM
  #162
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Impressive I guess if you have to deal with smog laws.
Old Dec 3, 2010 | 11:42 PM
  #163
topteam54's Avatar
All I wanted to add to this is stand by, she will soon be going under the knife .
Old Dec 4, 2010 | 03:57 PM
  #164
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Good. You need to get those runners opened up some and you will be above 400rwhp. I have some issues with my car from the dyno session. Trying to figure out why it did what it did. I have yet to have a nice smooth normal dyno graph.
Old Dec 4, 2010 | 04:06 PM
  #165
topteam54's Avatar
Well I'm trying to find a place to open them up (hint, hint). Hopefully al the top contenders are all ready for the next dyno day to just finally break that damn 400+ RWHP. I heard about your issues you were having.
Old Dec 4, 2010 | 07:26 PM
  #166
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If not try the morel lifters..they say they are good for 5-10whp over factory style lifters due to the tool steel body..they wont flex under high oil pressures and bleed down at all.
Old Dec 4, 2010 | 09:21 PM
  #167
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
havent read the whole thread but I think those are fantastic #s for a SR 350!!!!
As far as the rest of the hijack garbage Don is posting about what hes DONE not about internet reading/repeated garbage. Voice of experience means everything .
party on Garth!
Old Dec 5, 2010 | 03:27 PM
  #168
bdiroc's Avatar
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
Originally Posted by Burnout91
Slap on a pair of AFR Heads, you'll love 'em!
I love my AFR Heads, too!
Bill
glad your happy with them, I think until I upgrade the intake the edelbrocks will be perfect for my combo.
my car runs 13.01 @104 and weighs about 3700 lbs with me in it, and that is in just as bad as air you guys run at california dragway. my DA is almost always over 2000 and normally around 2800-3100 at NTR
Have you ran updated times since april 3 when you you ran vincent, I think you ran a 12.9 @105 1.83 60ft. and vincent ran 12.69 @ 109 1.94 60ft. Drag times says your DA was around 1800 to 2400 that day.
nice times for both but I thought you changed converters since then?
and vincents posi was out he said that day.
Old Dec 5, 2010 | 04:55 PM
  #169
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I changed to a Yank SS4000, but no new times yet. I hope it picks up a bit in both ET and MPH. But for now, your car is right there with mine, performance-wise. Enjoy!
Bill
Old Dec 5, 2010 | 05:29 PM
  #170
bdiroc's Avatar
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
Bill
please let me know how you do, im watching your results to see if I am going stealth ram or not.
I think you will run a couple tenths quicker as long as you hook, your stall was to low for stealth before
i'm opposite 3200 stall just little to high for my ltr setup.
Old Dec 6, 2010 | 10:52 PM
  #171
topteam54's Avatar
I'm planning on doing so, along with some other changes. I'll keep you guys posted as soon as I get those NEW numbers in
Old Dec 10, 2010 | 05:12 AM
  #172
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Originally Posted by VincentZ28
Well you can be the first to find out.
The advantage we have here is that it only cost us $85.00 per hour to dyno our cars and Kevin91z is doing the tuning. In short, we have seen a lot of different TPI combos on the dyno and we know what works and what doesn't work. This is the information we are putting out there for the rest of you to know.
I know this for a fact and seen it for myself, a bone stock G92 350 with a full exhaust system with Dyno Don headers will produce 248-255whp@4800.
We have seen a 383 with a Vortec manifold, fully ported E-Tec 200 heads, XFI268 Cam and Super Ram make 331whp. After welding up the manifold and porting the hell out of it and changing the cam to XFI292 it made 394whp.
Another car with a fully Extrude Hone TPI Edelbrock system(manifold,runners,plenum), Fully ported Corvette L98 heads, LT4 Hot Cam and Dyno Don headers made 331whp.
Thanks to Jerrywho, he discovered how to rework the manifold and siemese the runners to make peek hp above 6000rpms. And we are still not done. We are working on making over 400whp and still pass emission in California. We are not changing parts, we are going to work with what we already have.
Nice post, this is what I clicked on this thread for, but found pages of useless bickering.
Thanks for sharing
Old Mar 1, 2011 | 08:47 PM
  #173
Copchaser's Avatar
did you ever find out about the valvespring issue? What is the best (yet affordable) valvespring setup to be using on the 280xfi?
84z96L31vortec
Aug 20, 2017 12:16 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
