intake on a L98
Old Jan 15, 2011 | 11:32 PM
firehawk1724's Avatar
intake on a L98
Was wondering what are the the best aftermarket intake manifolds for a L98 that keeps the low end torque and increase HP to 300 plus? Other parts would be vortec heads or aluminum haven't decided yet a mild cam and shorty hooker headers with flowmasters...any replies are greatly appreciated
Old Jan 16, 2011 | 01:07 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: intake on a L98
If you stay with TPI, then then about the only intake left would be Edelbrock Hi-flow.
Old Jan 16, 2011 | 01:13 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: intake on a L98
could just port the stock base
Old Jan 18, 2011 | 08:18 PM
Re: intake on a L98
Porting isn't an option because I don't trust anyone machine work around me and that's not my expertise...but if there is something that can be bought I'm all ears
Old Jan 19, 2011 | 03:04 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: intake on a L98
u have a PM...
Old Jan 19, 2011 | 03:10 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: intake on a L98
https://www.thirdgen.org/forums/tpi/...g-project.html
he is one guy on here and there is also cruisinartvette who do good port work I have used both, you pay for shipping but it comes out great
Old Apr 3, 2011 | 08:05 PM
Mud's Avatar
Mud
Re: intake on a L98
Would that be with using stock runners with the eldelbrock intake or with using the edelbrock runners with the elderbrock intake.
Old Apr 3, 2011 | 08:25 PM
red rock's Avatar
Car: 1987 iroc
Re: intake on a L98
I have a set of SLP runners, the stock runners are too small and can't hardly be ported. If your going to change the intake manifold, you should change the runners also, check this out; https://www.thirdgen.org/runner-leng...ter-variations You can also find alot of info in here about porting and what benifits you can gain by it.
Old Apr 5, 2011 | 07:42 AM
88blueiroc's Avatar
Re: intake on a L98
You might want to check out a company called Tuned Port Induction Specialties. I had their intake setup on my last third gen and it ran awesome, low end torque was strong. Only thing, they are a little pricey.
Old Apr 5, 2011 | 08:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: intake on a L98
For bolt on car with more torque and hp across the TPI rpm range, any aftermarket TPI setup would be nice. FIRST is your best bang for the buck and will support a nice set of aftermarket heads and cam later down the road. Its bigger than other TPI setups so its capable of supporting abit more hp.
Cheaper options probably are single plane EFI or holley stealth ram or edelbrock proflo xt. They extend the rpm range due to shorter runners more tuned to higher rpms, and give up peak torque that TPI makes, but they will create a flatter torque curve below and above peak torque rpm. This makes for more average power up top and results in a faster car. I went with a stealth ram intake for my L98 and with supporting bolt ons, it ran high 12.9's in perfect air.
With medium/big cam and a good set of heads you have an 11 second car if it aint heavy. Miniram/stealth ram/single plane intakes will be a better buy if you want to go above 4500 rpm and make serious power and run fast
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
Formula_88AE
Sep 3, 2015 01:47 PM
